ISY Finder does not find ISY
The ISY finder loads, and it used to be able to find my isy device but no longer can. I have tried a few things but nothing works:
1) cleaned java cache/temp files, reinstalled isy finder
2) telnet to ISY device with IP (works), logged in, confirmed that IP is dynamic, and IP assigned is proper on my network
3) If I select "add" and specify: http://10.0.1.90, it says not found (even though this is the telnet IP). Any other option won't load.
4) I am on the same network, I only have 10.0.1.x subnet. I can ping + telnet to ISY device from the machine
5) turned off windows firewall to all networks (just to verify it's not interfering)
FYI - I can load the ISY web portal by visiting URL but I can't load admin console because it can't get past the isy finder screen.
Add desc to the end of the URL. Does that help.
http://10.0.1.90/desc may or may not need the / at the end.
Edited by Mecheng70
Thank you. Manually adding with http://10.0.1.190/desc works but I'm unsure why it won't find ISY on the network anymore. Must be something interfering with UDP broadcasting on the subnet?
What OS are you using?
My Windows machine is pretty much find it. But my Mac and Linux machines do not. I believe it's dependent on how your router is set up. There are probably people on here that are more knowledgeable about doing that than I am.
Windows 10. I did disable the Windows software firewall but it still didn't help.
