UD Mobile showing scenes are active
ISY4Me
I am only in day 2 of using UD Mobile and still learning.
However, I have noticed that after a sync, the scenes I have created in ISY are enabled by default (blue dot).
In the one test I performed, when I toggled the scene, it turned it off (blue dot went to clear blue circle) and it executed the scene off and turned all the related lights off.
Normally, these scenes contain special alterations of lightning configurations and are not enabled so I would expect the blue dot should always be off.
I am now running 5.3.3 and all it is still the same… first noticed the issue on 5.3.0.
Update 5/21
Further examination this morning reveals that if any element of the scene is on, then UD Mobile sees the scene as being on.  If all the lights in any of the scenes are off, then the status of the scene on UD Mobile is off or just the empty blue circle shows.
Edited by ISY4Me
Hi @ISY4Me,
I'm not sure I understand, I see no way to disable a Scene.
Some additional information:
The Scene Estimated Status Calculation is a feature of UD Mobile and not the ISY.  This may not work in every situation and/or may require nodes to be excluded from calculation in order to be a useful feature, this is true for some battery powered devices or controllers which are not responders.  If you would like to remove an item from calculation press the calculator icon when the scene is opened in UD Mobile.  Excluding all items from calculation will remove the calculated status and the toggle indicator. The app will have to be closed then reopened if all items are excluded as status is only updated when a new value is posted, closing the app will clear all values.
      377k
