Alexa Scenes
I have created a scene 'movie time' in ISY. The scene turns off most lights and dims others. I have then added the scene in the portal to Alexa.  The scene is discovered fine.  When I say 'Alexa, turn on movie time'; all the lights that are part of the scene come on full bright.  What am I doing wrong?
Ken
Ken
What happens when you control the scene from the isy directly
35 minutes ago, KenUD2 said:
It works fine
from the keypad button
The problem is that you've only configured it for when they keypad button is the controller.  how to accomplish this is a bit differnt between V4 and V5 off the ISY firmware.  In V4 there is a copy button you can use.  In V5, you need to click the root level of the scene and also configure the scene there.  The Red controller link for the keypad button is already done.
For Example:
with this scene, I need to configure it 3 times, Once at the root level (highlight now), and then again for each of the Red controller links.  Each can be different, or all three can be the same configuration.
You guys are the best!  Works great.  I just changed the default for the scene to be what we want to happen when alexa controls the scene.  Thank you very much for the very quick reply on a holiday!!
