Switching Between ISY Portal and MobiLinc Connect for Testing
I'd like to test UD Mobile using a remote connection (ISY Portal), but I'm still using Mobilinc Connect.  Anyone have any experience switching between the two?  Any issues switching back and forth?  I want to maintain both for awhile to see how node servers get implemented in Mobilinc X.  The node server implementation in UD Mobile is really nice to have.
Hi @mbking,
While the following has not been tested it may work.
If you have the Mobilic Portal installed on the ISY, uncheck "Use ISY Portal for remote connections" in UD Mobile.  Use the remote URL as described on the Mobilic website for connecting to the Admin Console with the last path removed (i.e /desc) along with the mobilic credentials.
Admin URL:
https://{ISY's UUID without colons}.admin.mobilinc.io/isy/{ISY's UUID with colons}/desc
Try this:
See the mobilinc website for detailed remote connections to the Admin Console and search for "Remote Admin Console Access"
https://mobilinc.com/features/mobilincconnect/
@Javi, couldn't get the above to work.  I think I can switch between Mobilinc Connect and ISY Portal within the ISY with relative ease, but we'll see.
What's the best way to request feature enhancements in UD Mobile?  There are a few things I can do in Mobilinc X that I can't do in UD Mobile, but UD Mobile has the edge in it's implementation of the node servers.
Hi @mbking,
I am unsure about the difficulty in switching between portals, especially on the Mobilinc side.  I believe Mobilinc also has a one time fee which will allow the use of Mobilinc with ISY Portal without the Mobilinc subscription fee, which may be lower cost then subscribing to both for a long period of time.
We do have many features planned, however it will take time.  Request can be submitted on the forum or on our GitHub issue tracker.
https://github.com/UniversalDevicesInc/UD-Mobile-iOS
https://github.com/UniversalDevicesInc/UD-Mobile-Android
