Lamplinc Blinks On & Off
I have a Lamplinc device in my family room that has been working fine.  I had to replace the LED light bulb in the lamp that is plugged into the Lamplinc with a new LED bulb. Now, when the lamplinc is on, the light is on.  Perfect.  But when I turn the scene off that turns all the family room devices off, this Lamplinc blinks the lamp on and off without stopping.  How to fix?
Try a different bulb. Phillips warm glow bulbs work really well with insteon
Edited by lilyoyo1
I tried swapping a bulb in another lamp connected to a different lamplinc that was working fine.  The problem stayed with the 1st lamplinc.  The swapped bulb worked fine in the 2nd lamp.  Wonder if I need to remove the 1st lamplinc from my devices and re-add it?
