Polyglot Node Server - Report Writer
Now that ISY is becoming grand central station for external systems thru the Polisy/Polyglot interface I need a way to report on all that data.
In it's simplest form if I could access device data thru the existing ISY Notification functionality it would suffice. But, currently I don't see a way to capture node server device data and put it in a email.
Maybe a Polyglot Node Server could pick up the missing pieces and generate report files saved to the local network, Polisy box or email notifications. Fancy formatting not required, a csv file for importing into Excel or whatever is enough.
Thanks,   -phil
Thanks,   -phil
I was trying to create a nodeserver that posts data to a google sheets cloud spreadsheet.  I figured out the nodeserver side, but the google sheets python library is another story.   I may attempt again this fall, unless someone beats me to it.
  • Thanks 1
If it just saved locally that would suit me. Maybe a custom configuration parameter with the local file path and credentials if needed.
