Wait not working
Have a 994i and noticed recently that the wait function is not working. have it in several scripts and everyone stops when it gets to the wait command.  Any suggestions?
Have you tried restarting the ISY?
Next suggestion would be to check the error log (Tools > Error Log) and see if there are any clues there.
Another question is what does the program do?  Post examples... If any of the conditions change during the wait state, it will end the wait state.   This is by design and not a bug.
Did the "wait" used to work?  Typically, when people say the "wait" isn't working, it is because the program starts over because of a condition being met within the "if".
Yes the wait command used to work.
reset, disconnected power and left off for 10 min
Can't figure out how to copy/past code. but here is the basic idea
if
     door violated (signal I get from my elk)
Than
    turn on entry light
    turn on garage light
     $GarageEntry=2
want 10 minutes
     $GarageEntry = 3
    turn off garage light
    turn off entry light
    $GarageEntry=0
else (no else)
GarageEntry gets set to 2 and never changes.
here is the error log
Time                          User         Code    Message
Sun 2021/07/18 09:10:52 AM    System    -5012    53
Sun 2021/07/18 04:21:43 PM    System    -5006    uuid:53
Sun 2021/07/18 04:21:44 PM    System    -5006    uuid:53
Sun 2021/07/18 04:21:50 PM    System    -5006    uuid:55
to paste code, right click the program name in the program tree, and select Copy to Clipboard.  Then click into a post and either just hit Ctrl-V (paste) or click the "<>" symbol in the toolbar first, and then Paste into the 'code' window that pops up.
I believe your problem is as I alluded to here:
and apostolakisl also mentioned
If the status of the door changes during the wait, then the program will stop and not finish.  The method to get around it is to use two programs (and there is two choices there as well)
Program checkfrontdoor
    frontdoor is violated
then
    run program frontdoorviolated (then)
else
    (nothing)
Program frontdoorviolated  (disabled)
     (nothing)
then
    turn on entry light
     $GarageEntry=2
    wait 10 minutes
     $GarageEntry = 3
    $GarageEntry=0
else (no else)
In this program, the end will be reached if the door becomes no longer violated while the waits are running.  However if the door is re-violated during the wait the program will start again from the top.
One more version:
then
else
    (nothing)
     (nothing)
then
    Disable checkfrontdoor
    turn on entry light
     $GarageEntry=2
    wait 10 minutes
     $GarageEntry = 3
    $GarageEntry=0
    Enable checkfrontdoor
else (no else)
In this version we added the disable and enable to the then body, this will cause the first program to ignore more violations until the second program finishes.
The second program should be always disabled, disabled programs still run when told to by another program, but not because the condition in the IF statement became true.
what is the (than)?
wrote a script that has no if just than. turns on a light, sets a bar. waits 2 min than turns the light  off and sets the bar back to 0. disabled it than ran. works. tks.
@FarmerGeek
It appears that your program doesn't work because the door that is violated is then restored prior to 10 minutes.  This re-triggers the program and is now false and the "else" clause is empty.  If you moved your "wait" and everything after it to the "else" clause it would probably work as you intend, though I'm not 100% sure on that since I don't fully understand the intent.
It is easy to see what is happening by simply watching the status of the program in the program tree in ISY console while you violate and then restore the zone.  You will see the program go from inactive (half red or half green . . . in your case half red), to solid green (running then) when the zone is violated.  It will stay this way as long as the zone is violated or until 10 minutes expires (at which time it will turn half green if the zone is left violated).  As soon as you restore the zone, the solid green (indicating the wait is running) will turn half red (indicating the program just evaluated to false and terminated.  If you put the wait etc in the else, the wait won't start until you restore the zone, at which point it will turn solid red for 10 minutes and then half red (unless you violate the zone again prior to 10 minutes at which point the process starts over.
  • 3 weeks later...
Also, you may want to note: You are disabling the IF section of a program with no IF lines in the section. There is nothing to disable.
