iOS test flight 0.3.7
Javi,
You included a note in test flight release 0.3.7 that is confusing me.
Quote
Note! Firmware patch needed as of 7/29/21 for missing programs tag.
@Chris Jahn did post a new firmware release 5.3.4 on 7/30/21 but the only fix it seems to contain seems to be unrelated:
17 hours ago, Chris Jahn said:
Fixes in this build:
0000780 - Program conditions using values with different units and different precision may not work correctly in some cases
Is this the same thing or different?
Hi @MrBill,
This could have been writing better. The note is in context of the whole release, and only related to Polisy. Without a patch iOS may hang during synchronization. This will not happen on Android due to how XML parsers are implemented.
"Node definition files will now accept lowercase directories and NLS file names, fixes POLISY. NOTE! Firmware patch needed as of 07/29/21 for missing programs tag."
