August 10, 20215 yr I just replaced my SD card with a new 32Gb card. I cleared the java cache and downloaded the launcher but the admin console won't open. I then formatted the card using telnet but still am unable to open the admin console. The launcher show my firmware as 5.3.4 even though I haven't loaded anything onto the SD card. Any suggestions on how to open the admin console? Edited August 10, 20215 yr by Techman
August 10, 20215 yr I just replaced my SD card with a new 32Gb card. I cleared the java cache and downloaded the launcher but the admin console won't open. I then formatted the card using telnet but still am unable to open the admin console. The launcher show my firmware as 5.3.4 even though I haven't loaded anything onto the SD card. Any suggestions on how to open the admin console? Have you tried the AC for that specific firmware version instead of the universal Launcher?!? [emoji848]
August 10, 20215 yr @Techman You need to use Admin Console (Cloud) and then reinstall the firmware + restore backup. With kind regards, Michel
August 10, 20215 yr Author 23 minutes ago, Michel Kohanim said: @Techman You need to use Admin Console (Cloud) and then reinstall the firmware + restore backup. With kind regards, Michel Prior to seeing your post I tried using a different link for the launcher, for 5.0.8 or below, which got me into the (LAN) admin console. All is good, I'm up and running. Thank you. Edited August 10, 20215 yr by Techman
