Programs not running
I am using version 2.7.6. Recently I am having problems with programs not running.
Everything has been going great for months and now all of sudden some of my programs do not run.
I am able to control all switches from computer with no problems.
Any ideas?
I think you'll need to provide a bit more information. What do the programs that are not running have in common? Are they triggered by INSTEON devices, or simply run on a schedule?
You also might consider posting the programs you are having issues with.
Michel - MikeB
You are correct my log does show a quite a few 1941 entries.
Here are a few.
A5 Bright (7) Sun 11/23/1941 12:16:18 PM System Log
A5 Bright (7) Sun 11/23/1941 12:16:19 PM System Log
Status 0% Sun 11/23/1941 12:17:32 PM System Log
A8 Sun 11/23/1941 12:46:15 PM System Log
A8 Bright (7) Sun 11/23/1941 12:46:16 PM System Log
null Fri 12/11/2009 04:29:52 PM System Start
/CONF/E Fri 12/11/2009 04:29:52 PM System -110022
The programs are running on schedules:
On Sat, Fri
Time is 3:00:00PM
Set ‘Living Room Recess’ On
Set Scene ‘KPL_Hall “B†Living Room Lamp’ On
Set Scene ‘Hall Upstairs 3-way’ On
Set ‘Hall Downstairs’ On
Wait 8 hours
Set ‘Living Room Recess’ Off
Set Scene ‘KPL_Hall “B†Living Room Lamp’ Off
Set Scene ‘Hall Upstairs 3-way’ Off
Set ‘Hall Downstairs’ Off
Set Scene ‘Family Room’ Off
-No Actions – (To add one, press ‘Action’)
The only other bit of info that might help is that I pluged the ISY into a GIG switch (CISCO) , and this seems to be when the problem started. I have since retuned it back to the 10/100 switch.
[/code]
Michel -
So do you think it is o.k. to plug the ISY into a switch that can do 1 GIG.
The port is auto sensing.
Michel - MikeB -
The only fix is to upgrade to the 2.7.7.
My setup did the same thing a few times. For now the other fix is turn off automatic time checks and set it maybe every few days.
I decided to go that way as I didn't want an alpha firmware. Though it has been reported to be very stable.
