Multiple Polisy issues
My Polisy device has been running somewhat reliable in the past but over the weekend it has gotten unusable and I could use a few ideas before I just do a hard reset and lose all my connections into ISY.
When I say somewhat reliable I mean that one node server in particular that I rely on has been flaky and not always reliably worked. A reboot usually helped, but all that changed over the weekend when I updated the Polyglot (57 updates since last time).
No when it starts (and to be fair I haven't checked the logs before hand so I don't know if this is new or not) I see two things happening.
a) The logs are going crazy and the same messages just keep printing forever in a very rapid fashion. I attached a log file for reference.
b) All node servers seem to have started AFTER 5 minutes. it took forever... except the wemo one and I get SQL Lite exceptions. I even tried removing the node server and I couldn't do it.
The ISY config is still correctly set btw.
Any information I can share here to help with recovery? or should I just factory reset and try again?
-Stephan
polyglot_log.txt
Don't do that!!! If you do, you'll create more issues than you'll solve.
At most delete a single nodeserver and reinstall it.     Don't hard reset the Polisy and start over unless support@universal-devices.com or a majority of the people here in the forum think that is your best option.
Like @larryllix mentions it appears your Dyson node server is an unhappy camper.  Check its setup, try restarting it individually.  Ask more questions here if you need help with the instructions.   Worst case, delete that nodeserver and re-install it.  Follow the instructions in the README.. (Click the name of the nodeserver in the store to find the README)
I'll disable the Dyson node server and provide more information on the wemo one (after checking out the README) tonight. Thanks for the responses so far.
