Network Rules on ISY/POLISY
Hello,
I suspect the ISY daemon is not running with permissions necessary to send broadcast packets. I have this rule which works flawlessly on native ISY - but packets are not sent when the same rule runs on ISY on POLISY..
Is there a way I can allow the daemon to send UDP to the broadcast address?
Michael.
I have tried the network broadcast address as well with the same issues.
I also tried Netcat on POLISY with the same issue (nc -u 255.255.255.255 50223). Netcat additionally documents -b flag on FreeBSD (https://www.freebsd.org/cgi/man.cgi?query=netcat) but this option is missing from the implementation on POLISY:
[admin@polisy ~]$ nc -u -b 172.20.255.255 50223
Password:
nc: invalid option -- b
usage: nc [-46DdEFhklNnrStUuvz] [-e policy] [-I length] [-i interval] [-O length]
          [--no-tcpopt] [--sctp]
          [-P proxy_username] [-p source_port] [-s source] [-T ToS]
          [-V rtable] [-w timeout] [-X proxy_protocol]
          [-x proxy_address[:port]] [destination] [port]
[admin@polisy ~]$
The nc command works - but I have wireshark running on another host and it does not show any packets when I send them. Changing the IP in the nc command to a unicast (where wireshark is running) and the packets arrive.
4 hours ago, Michel Kohanim said:
@MWareman,
I don't thing it's supported through UDP. Did you also try Multicast?
Awesome! This worked flawlessly.
Sending to 224.0.0.1 (the multicast address for "All systems on this subnet") did the trick. Since multicast implies udp anyway - is there a functional difference between selecting 'udp' or 'multicast' in the NR? Either appears to work the same and produce the same payload.
Thank you!
