2 Instances of NodeLink on same Pi4
Hello @io_guy
I have Nodelink running on Pi4 running buster. Has been working great feeding ISY994 v5.3.4
I am migrating to Polisy/ISY. But during the migration process I want to feed both ISY's Nodelink.
Can I run two instances of Nodelink from the same pi4? Is it as simple as duplicating the nodelink, changing the folder name and updating the config file and running at startup?
I am running DSCLink along with WCLinks. I upgraded the panel to use the evisalink network module, so I will have to turn on the repeater in one of the DSCLink's.
Are there any other obstacles or gotchas I might encounter?
Thanks very much,
-Tim
