December 19, 200916 yr I'm trying to clean up some links in my system. Could someone explain what the (6?) columns are in the following tables and the associated codes mean? I'm especially interested in the 22 code in the 2nd column.
December 19, 200916 yr Hello fasttimes, ISY-99i/ISY-26_INSTEON:Tools_Menu#Show_Links_Table_Database. 22 and 02 are deleted records. Using Restore on a device will delete these. Rand
December 20, 200916 yr Appreciate the question and answer, was looking for the same info also. When the test gives the result [ignore], what is it saying? I am seeing an [ignore] and a [failed], can I assume that it is saying that the unit that failed ignored the signal from the [ignore]?
December 20, 200916 yr Hi Paul, [ignore] means two things: 1. The device itself shall ignore this record 2. You should consider this record as a logical delete and ignore it With kind regards, Michel Appreciate the question and answer, was looking for the same info also. When the test gives the result [ignore], what is it saying? I am seeing an [ignore] and a [failed], can I assume that it is saying that the unit that failed ignored the signal from the [ignore]?
