Can't Backup without error
Tried to back up 994 tonight and ended twice with the following error. Do I need to restore with a previous backup or can I do something to repair the current running version?
The file is corrupt
Telnet to your ISY
Login
At the prompt, type the following followed by the Return button
RF /CONF/NODES/UN0472.BIN
Thank you @Techman, question. Will this deleted file in any way cripple or create any grief in the future do you think? Or will it get rebuilt or replaced somehow?
Thanks again,
Tim
While @Michel Kohanim has suggested in similar situations to delete the file, I don't know if it was the same type of file or the same path.  Would any file that erred during backup be OK to delete?  I don't think its a questions forum member can answer.  I've read this forum everyday since 2016 and I don't have anything in my bookmarks to use as a reference for this particular problem.
My vote would be that you open a ticket by email support@universal-devices.com and ask this question.  Don't worry this won't hold you up long... UDI support typically answers very quickly.
@TJF1960,
Yes, definitely an issue with a file relating to one of your nodes with the address 0472.
