Insteon switch follows program but lights will not come on or go off. switch does.
INsteon switch will turn on or off according to program and switch LED.  however the lights will not come on.  if I manually turn switch on or off the lights follow the switch.  Only from the program does the switch not function correctly.   I have deleted everything and rewrote still nothing.  i have tried a new switch also.
Mark
Mark
If you're still having problems post a copy of your program
Mark
I agree with @Javi
If this was a 3-way situation before Insteon, maybe the other end is what's actually connected to the light.
If that's the case you should make both switch controllers in a scene to keep them in sync.
