Calculation Help- Third Wednesday in month
I have things that run on the Third Wednesday of the month or others like the 2nd Friday of the month
I have been using this program to calculate week of month
WeekofTheMonth - [ID 0282][Parent 0219]
        $WeekofTheMonthTemp  = [Current Day of Month]
        $WeekofTheMonthTemp -= 1
        $WeekofTheMonthTemp /= 7
        $WeekofTheMonthTemp += 1
        $WeekofTheMonthTemp Init To $WeekofTheMonthTemp
        $WeekOfTheMonth  = $WeekofTheMonthTemp
and then I say day is (Monday, Tuesday, etc) using the ISY TimeData Nodeserver
and the week number is (whatever I need)
Is there a better way to do this?
Jeff
Yes.....  It's basically the same thing... But I use this program by @kclenden to set a number of date variables:
Set Date Variables - [ID 0104][Parent 0126]
        Time is 12:00:00AM
        // Determine Day of Week
        $sISY.DayOfWeek  = [Current Day of Week]
        $sISY.DayOfWeek Init To $sISY.DayOfWeek
        $iISY.DayOfWeek  = $sISY.DayOfWeek
        $iISY.DayOfWeek Init To $sISY.DayOfWeek
        // Determine the Month
        $sISY.DayOfMonth  = [Current Day of Month]
        $sISY.DayOfMonth Init To $sISY.DayOfMonth
        $iISY.DayOfMonth  = $sISY.DayOfMonth
        $iISY.DayOfMonth Init To $sISY.DayOfMonth
        // Determine the Month of the Year
        $sISY.MonthOfYear  = [Current Month (Jan=1, Feb=2, etc.)]
        $sISY.MonthOfYear Init To $sISY.MonthOfYear
        $iISY.MonthOfYear  = $sISY.MonthOfYear
        $iISY.MonthOfYear Init To $sISY.MonthOfYear
        // Determine the Week of the Month
        $iISY.WeekOfMonth  = $sISY.DayOfMonth
        $iISY.WeekOfMonth -= 1
        $iISY.WeekOfMonth /= 7
        $iISY.WeekOfMonth += 1
        $iISY.WeekOfMonth Init To $iISY.WeekOfMonth
        $sISY.WeekOfMonth  = $iISY.WeekOfMonth
        $sISY.WeekOfMonth Init To $iISY.WeekOfMonth
        // Create Month.Day Combo
        $iISY.Date_Scratchpad  = $iISY.DayOfMonth
        $iISY.Date_Scratchpad /= 100
        $iISY.Date_Scratchpad += $iISY.MonthOfYear
        $iISY.MMDD  = $iISY.Date_Scratchpad
        $iISY.MMDD Init To $iISY.Date_Scratchpad
        $sISY.MMDD  = $iISY.Date_Scratchpad
        $sISY.MMDD Init To $iISY.Date_Scratchpad
I re-paste the program rather than just linking to the original which can be found below because there is a minor change "Week of the month" calculations. This version uses the i or Integer version of the variable for inline calulations, then copies the value to the state variable.  The original used the state variable for inline calculation which results in false triggers of other programs for intermediate calculations.
Why set both state and integer variables for each value?   A state variable acts as a TRIGGER in an if statement, conversely an integer variable acts a FILTER in an If statement.
Original thread:
Edited by MrBill
Yes. no access to my ISY right now but.
If Wednesday
and
day of month >= 15
and
day of month less than or equal to 21
it's the third Wednesday of the month
I would use my technique using created variables to do the same easier.
$sISY.MM.DD
This technique was posted a few years ago.
