PG3 on Polisy
2 minutes ago, vbphil said:
@macjeffHow did you set all your log levels to Error only?
Go into the Node server and go to the LOGS button.   Then there is an option in there to set your log level.  I like that feature of PG3 which did not exist in PG2.  You had to set the log level in configuration or in the ISY Admin if it was programmed in.
On 3/16/2022 at 12:30 PM, bpwwer said:
Ok, thanks. I didn't notice any node servers going into failed state when I tested, but I may have had them stopped at the time.  I'll try again to see if I can reproduce what you're seeing.
3.0.50 seems to fix the backup issues
Spoke too soon.  Backup works under 3.0.50 but a majority of my node servers are not.  Either zeros or OLD data showing up.  I tried restarting Pg3, IoP, and the entire Polisy.
Most weather ones seem to be working.
Kasa, WirelessTags, TimeData, Ecobee, Harmony, Pushover, Linktap.   all Not working
I am going to send you my log file.
Everything was fine on 3.0.48 except for backup
any way to go back?
any way to go back?
There are many posts about this already. We are aware and @bpwwer is looking into it.
Sent from my Pixel 6 Pro using Tapatalk
I must not be monitoring the correct topics.  I monitor this one for Pg3, and the main one for IoP, and then the individual ones for all the node servers.  I will search but anything you want to send me to follow would be great.  I have been pretty busy and dont always look at every topic.
I pushed out 3.0.51 that should fix the problem, but I've been waiting for confirmation of that.
I was not able to reproduce the issue with any of the node servers I have installed for testing.  I suspect there was a case where I expected data from the store that many existing node servers haven't updated yet.  3.0.51 should work with those older entries.
It fixed the problem IF I delete and re-install the Node server.  I did that with two and they are now working but the others are not.
I tried several restarts.
I can give you accesss to my system if you need it but PM me.
I will PM you a new log file now.
Several of my node servers are also not working since 3.0.5... will upgrade to 3.0.51 and see if that corrects them.
No change. Here is my Elk Node server log fyi. thanks.
Also fyi, noticed the versions aren't matching, but understand if that is just a UI issue.
Version 3.0.51
Status: Connected
Frontend Version: 3.0.50
ELK_3-24-2022_50156_PM.zip
Edited by dbwarner5
Version 3.0.51
Status: Connected
Restart pg3 under the system menu or do sudo service pg3 restart
that should fix the version mismatch
but not the larger issue
Edited by macjeff
1 hour ago, bpwwer said:
Is Elk the only node server now having issues?
Try going to the ELK details, selecting log and change the log level to something different, then restart the node server.
I am having it on four different note servers now… Wireless tags, purple air, ecobee, pushover.
I also had the issue on Kasa and harmony Hub but a reinstall of those fixed.
@bpwwer @JimboAutomates  Good news. got them running:
-installed 3.0.5.2
-Front end Version matches Version
-ALL node servers were not working : Kasa, ecobee, elk, notifications, time date, Weatherflow
-One at time, I am changing the log level, stopping the NS, going back to dashboard, waiting, starting it again..
-So far they all are restarting successfully. Log level chosen does seem to matter, just changing it.
Only one that seems to still be struggling is Ecobee. It may just need more time? this line seems to be repeating:
Thread-37 udi_interface DEBUG Controller:shortPoll: controller:shortPoll: Skipping since discover is still running
Will keep an eye on it.
Thanks!!
All works fine except two things.
Minor issue- Ecobee did take a long time to update but it worked so I am ok
I reported this directly to bpwwer but its a Node server from Jimbo called Wireless Tags.
Still would not work so I tried an erase and install.  Still wont work after that nor will it give me link to authenticate.
I sent logs in but screenshots are attached.  So it was working before all the updates today which broke it.  Then even on the latest PG3 version it fixed all the others but this one had no data.  After reinstalling the Node server I only get the 1 node and cant authenticate.
This is still not working for me.  I have tried everything even a different slot.
I noticed yesterday after the upgrades all of my node servers showed the modification date of 3/24 at the same time.  I thought it was due to the upgrades
But today I noticed they all changed to 3/25 and all the same time
So I did a REFRESH store and the time changes.  So this is showing the CURRENT refresh time NOT the modification time.
Plus the time there is 4 hours ahead of my time.   log times in PG3 are correct so its just the modification time inside PG3 store that is showing both the current time (After refresh) and the wrong time zone.
** Showing the correct time of modification, and only on those modified, is important because thats how I know one of my node servers was updated!!!
Edited by macjeff
@macjeffHi. My WirelessTag NS is still working this morning on 3.0.52.
There's one place you could check on and that's your WirelessTag Manager Account. You should see an authorization for UDI Polyglot V2 Node server. See snapshot. It will show V2 even if you installed PG3. That's a bug that hasn't been fixed. I suppose you might try Revoking it there and re-install the Node Server, especially if you're unable to get the authorization working. Just a thought. Log in to your WirelessTag portal. At the bottom click on Settings and choose Account.
The problem is that I deleted what I had.  The issue is the Authorization part is broken.   I have no access in the portal.  If I use Pg2 I get the access and it works.  Then I can revoke it as you said, but when I go to pg3 and add it back I dont get the auth page so I cant go any further.  The errors clearly tell me its not going to work.
I even tried manually putting the auth code in there and it wont work.
So whatever you do, dont delete the Node server or you can probably not add it back.
Or try adding it to a second slot.  See if it works.
For now I have to wait for Jimbo.  I can go back to Pg2 until its fixed.
These errors are in BLUE in the configuration where in Pg2 and before in Pg3 it would say click here to auth
REST Server (False) not running. check Log for ERROR
No NSDATA Returned by Polyglot key=None data=None
Unable to start server, no NSDATA returned client_id=None client_secret=None
This is the entire log!!!  And it does not grow
2022-03-25 10:16:29,293 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-03-25 10:16:32,410 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.38 Starting... 2022-03-25 10:16:32,624 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.0.52 [ISY: 5.4.1, Slot: 12] 2022-03-25 10:16:32,627 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '172.16.1.210', 'netmask': '255.255.255.0', 'broadcast': '172.16.1.255'} 2022-03-25 10:16:32,629 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:1888 2022-03-25 10:16:32,636 MainThread udi_interface INFO Controller:__init__: WirelessTag Controller: Initializing 2022-03-25 10:16:32,637 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: wtcontroller not found in database. 2022-03-25 10:16:32,638 MainThread udi_interface.interface WARNING interface:send: MQTT Send waiting on connection :: {'config': {}} 2022-03-25 10:16:32,961 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success) 2022-03-25 10:16:32,963 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:53:2c:34_12 - MID: 1 Result: 0 2022-03-25 10:16:33,182 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-03-25 10:16:35,644 MainThread udi_interface.interface INFO interface:addNode: Adding node WirelessTagsController(wtcontroller) [None] 2022-03-25 10:16:35,646 MainThread udi_interface.interface INFO interface:setController: Using node "wtcontroller", driver "ST" for connection status. 2022-03-25 10:16:43,377 Thread-5 udi_interface ERROR Controller:handler_nsdata: No NSDATA Returned by Polyglot key=None data=None 2022-03-25 10:16:43,381 Thread-3 udi_interface ERROR Controller:handler_params: oauth2_code not defined, assuming False 2022-03-25 10:16:46,429 Thread-9 udi_interface ERROR Controller:rest_start: Unable to start server, no NSDATA returned client_id=None client_secret=None
BTW...thanks for your help!!!
Edited by macjeff
55 minutes ago, JimboAutomates said:
This is an error because PG3 is not sending the information needed by the NS. Need help from @bpwwer
Thanks!!!
