I moved ISY from 994 to Polisy today.  I have had Network Resources talking to my Autelis for years to control my pool lights, so I'm not trying to set up something new.  I thought I was just going to go into the Autelis Settings (on the Autelis) and change the ISY IP address to the Polisy IP address and be done.  But no joy.  Along with a place to enter the ISY IP, there is a place to enter ISY Port.  I've tried ports 80, 8080, and 8443.  You can tell I have no idea what I'm doing when it comes to ports.
Edited by carealtor
change title
Polisy IP address with port 8080 (with HTTP) or port 8443 (with HTTPS) should work. You may have to reboot both ends,  as some drivers only do a grab of setup info, at boot time.
You want 8080... same as the admin console with http mode.  I don't think the Autelis Control has whats needed to use 8443 with https.
I'm not actually moving my ISY to polisy until February because we are going to be out of town for a large chunk of January, so I can't confirm for you whether it works correctly or not, but it should.
can you open the admin console with the http (8080) row in finder that looks like this?
if so you should put the same IP address and 8080 in the autelis interface.  Save it and restart autelis and then make sure that information is what's set after autelis reboots.
(FWIW.... finder didn't find Polisy at 8080... i had to add that row manually, but after I did I could open the admin console using it)
If you can't get it working, reply again and I'll try moving my autelis over to my test installation to see if there's any hitches.. I would have already tried while writing this, except my pool is winterized right now so I need to venture out to the pool equipment to turn off some individual breakers then turn the sub-panel back on.
Edited by MrBill
Autelis hasn't shipped product or answered an email in years, so it might be good to seek alternatives to your Autelis interface.  If it goes belly up, like mine did, you will be SOL.
Edited by PatPend
I've been testing things by going back and forth between ISY on 994 and ISY on Polisy and changing the IP and port in Autelis as appropriate too.  It still works with ISY on 994, so that's something good.
When I run the Network Resource on ISY on 994 using the Test button, I get a response of H and it works (pool light turns on).  When I do the same on ISY on Polisy I get a response of N/A and it does not work.
I've done countless reboots of everything to no avail.
@carealtor
The first screenshot handles information transfer in the direction Autelis -> ISY... that is the state variables that are updated.
The NR is the information flowing in the opposite direction ISY -> Autelis.  that is sending the command to turn on the lights.
My first inclination would be to try changing the hostname on the NR to the IP address of the Autelis.  Perhaps Polisy isn't keeping track of hostnames the way a 994 can.  (on my network it never works anyway, so I always need the IP address).
  • Thanks 1
2 hours ago, MrBill said:
@carealtor
YES!  That solved it.  Also, thanks for the explanations in the first 2 paragraphs.  I have to admit I wasn't really grasping how this worked.  I now see that IP and port for ISY on Autelis were never actually a problem.
I'm glad you elaborated on the problem... otherwise we might not have gotten it solved.
  • Thanks 1
  • 4 months later...
@MrBill
I switched to Polisy recently. My setup utilized IP addresses in the ISY admin console. I was still not able to send messages to my Autelis. I updated the IP address in Autelis local webpage along with username and password for my ISY. I rebooted all and still unable to control the Autelis.
The step that fixed it was opening each network resource in the ISY admin console and saving it again without changing anything. Once I did that for all the network resources related to the Autelis, I was able to fully control Aurelia from ISY. Why that step?  No idea. But it worked!
9 hours ago, TJMax2 said:
@MrBill
not certain.  If you imported a 994 backup and restored it on polisy, it's very possible that the restore routine has a minor bug that gets fixed by opening and resaving NR's
