Login problems
This should work, but it doesn't.
https does work.
http was working yesterday, but now today it isn't.
My second problem is that I have to use the Add button every single time.  With ISY on 944 I had to use the Add button, but it would stick and I wouldn't have to use the Add button the next time.  With ISY on Polisy it doesn't stick.  I have to use the Add button every time.
Clear out your Java cache including all applications and then download the ISY launcher.
Yeah, I tried that several times before posting.
Are you using wifi?
My Launcher works when on Ethernet but when I switch to WiFi the Launcher goes blank but I can SSH and use the Polisy webapp.
I also manually typed the information as well but get Not Found.
It must be the latest update because it was working before.
27 minutes ago, mmb said:
Are you using wifi?
No, not using WiFi.
Interestingly, it is working for me now.  I've been working all kinds of things and one of the things I've done is push the multifunction button on the front of the Polisy once.  This may or may not have solved this.
No, not using WiFi.
Based on an earlier post, the button push solved the problem
