Setting Parameters on Zooz ZSE18 Motion Sensor
I was having a heck of time with this.  Z-Wave in general wasn't working as expected.  I did three things: updated to 5.3.4, ensured that Java was up to date, and cleared the Java cache.
Now I needed a way to consistently set the parameters.  There are, hopefully, better ways but this worked for me:
In the UD admin console, Main tab, in the ISY section
1. Right click the ZSE18 motion sensor entry.
2. Click on Z-Wave
3. Click on Set Configuration Parameter
4. Enter the Parameter Number (e.g. 18)
5. Enter the parameter size (see documentation that came with the device) 1, 2 or 4 bytes
    e.g. parameter 18 is 2 bytes
6. Enter the value
    e.g. values for parameter 18 are 3-65548, value+3 equals number of seconds, a value of 42 would be 45 seconds
7. Open the device by twisting the two halves counterclockwise, about 15°, and pull the halves apart.
8. Click on the set button of the dialog box, immediately followed by pressing and holding for 5 seconds the Z-Wave button* of the device. (Manual wake-up mode)
9. The blue light on the device will start to flash after 5 seconds.  Release Z-Wave button. (you may get error messages, which you can ignore.)
10. Click on close.
*The Z-Wave button is the button bellow the battery (the only button).
I agree, it's dumber than dirt, but if you have a better way that works consistently, put it here.
Edited by Old Surfer Dude
added tags
2. Click on Z-Wave
6. Enter the value
10. Click on close.
Unfortunately that's how you update parameters
  • 4 weeks later...
Dear Old Surfer Dude,
I have been unable to add/include the Zooz ZSE18 motion sensor to my ISY994, running 5.3.4.  Do you know of any settings or tricks required to get this to work?
What are you trying to get to work
Can’t get the device to include successfully.
