ISY-99 Pro hangs after repeated HTTPS connections
This is the second time now my ISY has become non-responsive after using the HTTPS REST interface. It appears to still run programs (but further investigation is needed), however, it loses all network connectivity - it will not respond to HTTP/HTTPS or pings. The "solution" is to unplug it from the PLM, wait 15 seconds or so and plug it back in.
This last time I let it run for a couple of hours before power-cycling it and it did not recover.
Any suggestions? Is there something special I need to do in order to make this more reliable? I am running firmware 2.7.5.
David
