lalang Posted January 7, 2022 Posted January 7, 2022 I setup my Polisy sometime ago and now i have some time to work on it. My problem is when I login through my UD ISY software and click on the "Open Polyglot" tab in the top right corner I get my Dashboard which says its online, but I cant open any of the nodes. Everything says "Unmanaged" and there is nothing I can do but install new nodes. Everything else is just for viewing . no editing or deleting. What an I missing? Thank you in advance !
lilyoyo1 Posted January 7, 2022 Posted January 7, 2022 6 minutes ago, lalang said: I setup my Polisy sometime ago and now i have some time to work on it. My problem is when I login through my UD ISY software and click on the "Open Polyglot" tab in the top right corner I get my Dashboard which says its online, but I cant open any of the nodes. Everything says "Unmanaged" and there is nothing I can do but install new nodes. Everything else is just for viewing . no editing or deleting. What an I missing? Thank you in advance ! Are you logging in on the portal or your polisy
lalang Posted January 7, 2022 Author Posted January 7, 2022 2 hours ago, lilyoyo1 said: Are you logging in on the portal or your polisy I'm logging in through my portal, but then the screen looks like I'm in the Polisy.
lilyoyo1 Posted January 7, 2022 Posted January 7, 2022 The portal only shows cloud based nodeservers. You have to log into polisy
MrBill Posted January 7, 2022 Posted January 7, 2022 2 hours ago, lalang said: "Open Polyglot" that's the cloud version of polyglot... you need to review the instructions for logging into your Polisy.
carealtor Posted January 7, 2022 Posted January 7, 2022 Can't help but wonder if these will ever be combined into one UI. It IS confusing.
lalang Posted January 8, 2022 Author Posted January 8, 2022 So I'm trying to login to Polisy directly and the browser will not connect (Chrome, Edge and Firefox) I've turned off my firewall and still nothing. I can make a SSH connection and login, but not through a browser. Any ideas? Thank you in advance.
MrBill Posted January 8, 2022 Posted January 8, 2022 are you using https://<the.ip.of.polisy> you must use https not http
lalang Posted January 8, 2022 Author Posted January 8, 2022 Yes.. I’m using HTTPS://ip address of polisy
lilyoyo1 Posted January 8, 2022 Posted January 8, 2022 7 hours ago, lalang said: So I'm trying to login to Polisy directly and the browser will not connect (Chrome, Edge and Firefox) I've turned off my firewall and still nothing. I can make a SSH connection and login, but not through a browser. Any ideas? Thank you in advance. Try using Firefox
lalang Posted January 10, 2022 Author Posted January 10, 2022 I’ve tried Firefox. I noticed the screen that say “Go back recommended”/ “Advanced” splashes for a split second then goes to the “cannot connect” screen. It’s really odd. Should I do a factory reset and just start over?
lalang Posted January 11, 2022 Author Posted January 11, 2022 I think I'm in over my head. I reset the Polisy back to factory default. When i connect using SSH I get FreeBSD. It won't allow me to reinstall MongoDB or Polyglot-v2. It appears I lost the OS and I don't know where to go form here.
MrBill Posted January 11, 2022 Posted January 11, 2022 29 minutes ago, lalang said: I think I'm in over my head. I reset the Polisy back to factory default. When i connect using SSH I get FreeBSD. It won't allow me to reinstall MongoDB or Polyglot-v2. It appears I lost the OS and I don't know where to go form here. Open a ticket, email support@universal-devices.com 1
kzboray Posted January 12, 2022 Posted January 12, 2022 (edited) @lalang Your Polisy may just have to old an install on it. You can use the following commands to install both MongoDB and ISY on your Polisy. For the older Polisy's that are a bit behind in updates, you can try the following. First: curl -s https://pkg.isy.io/script/update121.sh | sudo bash sudo shutdown -r now Wait for the Polisy to completely reboot, this can take quite awhile (~15min). Now: cat /usr/local/etc/udx.d/static/update13.sh | sudo bash sudo shutdown -r now Once again wait for your Polisy to completely reboot. Your Polisy should now be available in the ISY Launcher. Edited January 12, 2022 by kzboray 1
lalang Posted January 12, 2022 Author Posted January 12, 2022 Thank you kzboray. I followed your instruction and at first nothing changed. I decided to to run "sudo rm -rf /var/db/mongdb: followed by "sudo reboot' and I'm able to call connect to the polisy using Firefox. Thank you for your help !!
