oauth2 token for PG3 version
Spoke with @bpaauwe and we think this is actually a bug in PG3 which should be fixed in the next release.
Released 3.0.4 which should work better, but it still can fail due to an issue with PG3 that will hopefully be fixed soon.
No go and showing these two errors. I'll wait for the PG3 update. No hurry.
Thanks, Gary
REST Server False not running. check Log for ERROR
Unable to start server, no NSDATA returned...
Hi @Jimbo,
Installed Wireless tag node server over the weekend and had the same error on PG3 that Gary had,  ERROR: Unable to authorize, no client id returned in Node Server Data. Check Log for ERROR
I was able to revert PG2 back into operation. Will you post once we should try again?
Tim
Edited by TJF1960
Yes,.I'll try to remember to post in this thread
Got the same errors
Seems like a fix is on the way but included screen shot of them below as an FYI
Everything updated and rebooted / restarted
If additional logs are needed let me know.
Edited by stevehoyt
