PG3 ELK Nodeserver 3.0.13
I moved from the Elk Module to the Elk nodeserver on PG3, purchased from @Jimbo.
Its fantastic. Conversion though did mean redoing each program. So I did a Copy Folder to Clipboard of My Programs and had a reference for each program to update it.
You will lose voice however, for now. Alexa is a possible replacement option for voice. not as neat / smooth, but works well.
  • 3 weeks later...
25 minutes ago, dbwarner5 said:
then restart PG3 via sudo commands?
To upgrade PG3 and everything else from the command line:
 sudo pkg update && sudo pkg upgrade
Thanks. I actually followed the earlier directions: upgraded PG2 then through sudo, restarted polisy which restarted IoP (ISY on polisy), PG2 and PG3.
All worked after startup!
now running 3.040 version on PG3
thanks!
***UPDATE: Query all ran fine last night!!
Edited by dbwarner5
UPDATE
