waffles Posted January 4, 2022 Share Posted January 4, 2022 I was wondering if the API is working again (still working) for the 9000 series thermostats. From the GitHub instructions https://github.com/dbarentine/udi-honeywellhome-poly..... I have gotten to this step and created my own Nodeserver KEYs. Entering them here: .... results in this error message: Any thoughts on what this means and more so, how to resolve it? Link to comment Share on other sites More sharing options...
waffles Posted January 15, 2022 Author Share Posted January 15, 2022 On 1/4/2022 at 6:17 PM, waffles said: I was wondering if the API is working again (still working) for the 9000 series thermostats. From the GitHub instructions https://github.com/dbarentine/udi-honeywellhome-poly..... I have gotten to this step and created my own Nodeserver KEYs. Entering them here: .... results in this error message: Any thoughts on what this means and more so, how to resolve it? made some progress.... I found the issue. I had a 'space' that didn't belong in the Callback URL So it was my fault. Link to comment Share on other sites More sharing options...
waffles Posted January 15, 2022 Author Share Posted January 15, 2022 Now I am stuck at the next step: When I try to log in with my Totalcomfort Honeywell Home credentials I get this: However, these credentials work fine when I go through their portal: So I wonder if I have now hit a hard wall and my model is not compatible with their Home product line, hence not supported, even though some of the naming suggests it. Can anyone confirm? Link to comment Share on other sites More sharing options...
Eric hill Posted February 9, 2022 Share Posted February 9, 2022 When I goto the control center I change temperature but it doesn't change on my thermostat Thermostat says register but im already registered Going back to regular old thermostat these smart items are not that smart at all Link to comment Share on other sites More sharing options...
Geddy Posted February 10, 2022 Share Posted February 10, 2022 On 2/8/2022 at 11:30 PM, Eric hill said: When I goto the control center What are you calling "control center"? Are you using an ISY994i or are you just meaning the Honeywell TotalComfort app? On 2/8/2022 at 11:30 PM, Eric hill said: Thermostat says register but im already registered What is asking you to register? If you have an ISY994i or Polisy running node server then you need to have a TotalComfort account to enter the login credentials in the node server settings. Link to comment Share on other sites More sharing options...
Geddy Posted February 10, 2022 Share Posted February 10, 2022 @waffles since it's been 4 weeks with no other replies to your question I'd say the model you're trying to attach isn't supported. It also appears the developer (@dbarentine) for this node server isn't as active to give updates or expand models that it supports. Link to comment Share on other sites More sharing options...
