RickL66 Posted December 31, 2009 Share Posted December 31, 2009 Is there a way to save the current state of a few devices to restore them to their original state later? Example - I may have my kitchen under-cabinet lights dimmed 40%, my den lights on, the hall lights off, and after doing a global all-off, I want to restore the kitchen under-cabinet lights back to 40% dim, the den lights back on, and the hall lights off if they were turned on after the global all-off. Thanks, Rick Link to comment
Michel Kohanim Posted December 31, 2009 Share Posted December 31, 2009 Hi Rick, Currently no, but it's surely on our todo list. With kind regards, Michel Link to comment
RickL66 Posted December 2, 2011 Author Share Posted December 2, 2011 Hi Michel - Just want to see if you have ever gotten to this "to-do" and made it possible to save the current state of some devices to restore back to the saved state? Link to comment
Michel Kohanim Posted December 2, 2011 Share Posted December 2, 2011 RickL66, Sorry to disappoint but no. With kind regards, Michel Link to comment
polexian Posted December 4, 2011 Share Posted December 4, 2011 Rick, I beleive you could do it with variables and programs. This is for straight on and off. Variables MainLight1 MainLight2 Program 1(Disabled)Name:CurrentStateMainLight1 If mainlight1 is on then variable Mainlight1 = 1//(For on) else variable MainLight1 = 0//(For off) Program 2(Disabled)Name:CurrentStateMainLight2 If mainlight2 is on then variable Mainlight2 = 1//(For on) else variable MainLight2 = 0//(For off) In any program you want to remember the states then call the program you need to remember the states with. The above programs will only run when called because they are not enabled. When you turn the scenes back on with a program then run these programs for each light in the scene. Program3(Disabled)Name:Mainlight1RestoreState If variable MainLight1=1 then insteon.mainlight1 = on else Insteon.mainlight1 = off Program4(Disabled)Name:Mainlight1RestoreState If variable MainLight2=1 then insteon.mainlight2 = on else Insteon.mainlight2 = off Link to comment
polexian Posted December 4, 2011 Share Posted December 4, 2011 Now for dimmed lights you can use this program for the nearest 10 or however specific you want to go all the way to 1. If Status 'Equiptment / DiningRoom / LightDining' >= 90% And Status 'Equiptment / DiningRoom / LightDining' <= On Then $CurrentStateMainLight1 += 10 Else - No Actions - (To add one, press 'Action') Link to comment
RickL66 Posted December 4, 2011 Author Share Posted December 4, 2011 Thanks polexian - I never thought of it that way, I shall give it a try! Link to comment
hackwright Posted December 6, 2012 Share Posted December 6, 2012 I'm doing something similar with about 20 devices so am only going to 25% increments for the dimmable ones to cut down on the number of programs (i.e., Off -> Off, 1-25% -> 25%, 26-50% -> 50%, etc.). My goal was to restore the prior state after turning off a scene. However, I'm not storing the state of the devices in variables but instead in a dedicated "Prior State" scene using Adjust Scene when the associated devices change state. I feel this is a more simple (don't need the multiple "restore the status" programs for each device / dim value range, not to mention all of those pesky variables), durable (survives a power failure) and aesthetically pleasing approach -- I just have to turn the "Prior State" scene on just like any other scene and that's it. Link to comment
hackwright Posted December 6, 2012 Share Posted December 6, 2012 But it sure would be nice if ISY allowed a set device state or adjust scene command to take a variable or even another device state as input so we wouldn't have to mess around with these dimmable state ranges in the first place... Link to comment
Michel Kohanim Posted December 7, 2012 Share Posted December 7, 2012 Hi hackwright, High on our list! With kind regards, Michel Link to comment
