Renovating my house. Have 3 switchlinc dimmers go bad at the same time. No surges. One i was able to pull the reset tab and get the paddle to work. Gonna try and restore in isy. The other 2 nothing works. Any one run into this. Seems odd that 3 went bad at the same time.
Sent from my SM-G960U using Tapatalk
Are any of the LED indicators lighting or respond if you try and add them to your Administrative Console? There was a run of the older SwitchLinc modules. Where you could control them with commands but the Local Buttons did nothing. Bad run of tact switches, They would click but nothing happened.
If completely dead. I would suspect power supply issues or voltage spikes as mentioned.
One of them does. The other 2 no led indicator lights lit. But if i push in the reset button i get a led indicator light. When i let go no led indicator lights
