Keypad Linc 6/8 Button
Hi,
One additional issue. I have one Keypad Linc conifigured for 8 buttons however, the ISY only can "see" it as a 6 configuration. I have removed and re-added the device however, still only 6. Also in the event viewer, the ISY does not show any traffic if button 7 or 8 is pressed.
Any help would be appreciated.
One has to reprogram them from one type to another. The steps are in the instructions, available online from smarthome if you have lost them.
Hi Oberkc -
The keypad is already set up as an 8 button, I also attempted to reset the keypad (per the smarthome instructions) and the ISY still only shows this it as a six button.
Hello pacificsloop,
ISY reads a byte in the KPLs firmware to determine the number of buttons. As such, I am almost certain that your KPL is currently in 6 button mode. What you need to do is:
1. Pull out the set button and wait 10 seconds
2. Push the set button back in and leave it in for 10 seconds
3. Press and hold buttons A and H before releasing the set button
Remove the KPL from ISY and then add it again.
Hi Oberkc -
Hi Michel,
Still no luck. I have reset the KPL, changed it to 6 button mode and back to 8 (using the instructions you provided). I have removed the device from the ISY and attempted to re-add. After button D, the ISY now appears to get "stuck".....with a message "initializing system". I attempted a reboot and same problem.
As an FYI, my old home-linc software sees this as an 8 button device.
Thanks for any additional help / ideas you have.
