WeatherLink stopped updating
@bpwwer Hi, Weather link has been running for about a day on PG3 but it stopped updating at about 3 AM. I copied the log shortly before  the updating stopped. Also restart didn't work. Had to stop start restart.
Thanks Gary
New Text Document.txt
@garybixlerThat's strange.
It looks like this was called from a query, is that right?
It crashed because it didn't find an 'indoor' node.  Based on the data just before that, it looks like you have an indoor sensor so should have an indoor node.   Do you have an indoor node?
I don't see anything wrong in the code that would cause this.  It's like the indoor node disappeared before it tried to update the node values.
@bpwwer Yes, the unit itself has an indoor temp and humidity sensor. I was wondering because the PG2 version has an indoor node. Only node one is loaded into the PG3 version. I added a couple of snippets from the PG2 version.
Thanks Gary
Edited by garybixler
The PG3 version should have both nodes too.
I just pushed out version 2.0.2. I made a change that should prevent the crash, but I don't know why the node wasn't created.
If it doesn't create the node when you restart, can you can post the first 30 seconds of the log after the restart?
