Oh No!!!
Spent some time today while watching football and tried to upgrade to version 2.7.8 but I could not even get past the backup procedure. I keep getting an error message that reads, "Could not create the zip file" and "Could not retrieve file /CONF/UDFLPL/.XML". That's my first problem. My second problem is:
I seem to have lost the 99i Administrative Console button I had stored on my desktop to access my ISY. But here's the really weird thing: Last week I spent some time placing all of my devices, scenes and links into folders sorted according to the rooms the device is located in. Now that I have had to go back to logging on by opening Internet Explorer then clicking in the favorites on my ISY the folders have disappeared AND there is no longer a new folder icon on the tool bar that would allow me to recreate my folders.
Is this something I did or what? I really don't understand where my folders and the new folder icon disappeared to!!!
Hi Mike,
There is a way to remove a file, but I think in this case you would lose your floorplan so I will wait for Michel to advise you.
If your link is to the UDI site then you will see the console through older firmware (no folders). You can set a new bookmark to http://ISY in IE to access your ISY locally.
Rand
I was able to get the ISY Finder back onto my desktop thanks to a search in the forum and this address http://www.universal-devices.com/99i/2.7.6/admin.jnlp and the folders are back as they were originally. (I just noticed this version indicates version 2.7.6 and I am running version 2.7.7. Is this an issue? When I click on the "About" tab in my system it shows I am running 2.7.7.)
BUT, I am still not able to take a backup of my current system without receiving error messages (see previous post) telling me the file cannot be saved. So consequently I don't want to risk upgrading to version 2.7.8 until I can be sure I have a known good backup. Although my system is small I don't want to have to redo it!!! :(
Any help is greatly appreciated
HAPPY NEW YEAR!
Hi NewTech,
Please do the following:
1. telnet to your ISY (http://www.universal-devices.com/mwiki/ ... o_Your_ISY)
2. login
3. type (case sensitive): RF /CONF/UDFLPL/.XML
Michel,
Sorry to be a pain... I did as you said and was able to telnet into the ISY then typed in RF /CONF/UDFLPL/.XML but I still cannot make a backup copy of my ISY. Any ideas? The progress bar gets to about 55-60% then stops and within about 10 seconds I get the two error messages.
Me again...
The progress bar when trying to backup gets to CONF/UDFLPL/.XML then times out.
Okay, I tried once again tonight to upgrade to version 2.7.8 but still no luck! I ensured that I did indeed download the upgrade for 2.7.8 for the 99i, logged onto my ISY using http://192.168.xxx.xxx/admin, made a backup copy of my ISY configuration then tried to upgrade. Here are the error messages I keep receiving:
1) Socket Open Failed Java.io.IOException: An existing connection was forcibly closed by the remote host and,
2) Upgrade Failed :java.lang.NullPointrerException
So, what am I missing here?
Thanks for your time!
Hi Mike R.,
Please do let me know what firewall software you have. In most cases the issue is firewall.
Michel,
I am using Trend Micro. I have disabled this firewall and attempted to upgrade with no luck. The one thing I haven't tried is to upgrade on my desktop computer which has a wired connection. I'm home from school today due to a snowday :D and my intent is to get this thing upgraded!
Well, guess I'll be calling tech support because I cannot get this thing to upgrade. Have to go run errands right now but will try later. Is there a special number I should call?
Hi, Michel! Happy New Year!
I have rebooted the system several times and I've unplugged it so the ISY has no power either from the PLM OR the A/C adapter. The one thing I haven't done yet is to unplug the PLM.
Back at school today but more snow forecasted for tomorrow so, if we have another snow day I'll try calling tomorrow.
Michel, as always your dedication to customer service is outstanding and I truly appreciate your help.
Michel,
I have NO IDEA what I did but all of a sudden I WAS able to upgrade to 2.7.8. I cannot explain the process in detail but I do know that my firewall was on and I used a WiFi connected computer.
I also viewed this post from sk8er02:
At first boot, yes, the lights blinked but only for a second. After that, only the power light remained solid. The only way I was able to access it with 2.7.8 installed was with Telnet. I tried the following...
http://isy/admin
http://www.universal-devices.com/99i/2.7.8
http://www.universal-devices.com/99i/2.7.8/admin.jnlp
Also, after going back to 2.7.7 and posting this I noticed things in the Network module were not working in programs. They just read "Response type=8" in existing programs and it wasn't in the drop down list to use in new ones
I used their method to access my ISY http://www.universal-devices.com/99i/2.7.8/admin.jnlp and this is when I was able to complete the upgrade.
So far everything still seems to be working fine although, as I said earlier, my system is very small for the time being.
I hope this little tidbit of information assists you in maybe trying to figure what the heck was going on with my system. One other thing I noticed... You said the ISY goes through a migration process on first start-up with 2.7.8 and to be patient. My system powered up in the same time frame as before the upgrade. Don't know if you need this info or not but here it is anyway! I'll keep a close eye on my system and keep you posted on any possible issues.
Michel and everyone else who assisted me with this... A GREAT BIG THANK YOU!
