Installing Polyglot-V3 on existing RPi
Before I dive into Polyglot, I thought I'd check the depth of the waters.
I found the instructions to install Polyglot-V2.  Seems straight forward enough, but there was no mention of installing it on an existing RPi, that has a desktop, some existing projects, etc.  I assume that I open a terminal window and follow the instructions starting at the command line interface.  Right?
I didn't find a similar set of instructions for -V3.  Am I missing something?
Ultimately, I hope do run a program on the ISY994i to monitor the wireless remote soil moisture sensors (that I am developing) to control appropriately the valves on my gravity fed irrigation system using MQTT communication.
Big elephant, small bites.  Ployglot with the MQTT node server looks like one path forward.
Thanks for you input!
OSD
ps, Did I read that node servers are called "Poly's"?  Shouldn't they be called "Glots"?
OSD
V3 is for polisy only. It can't be downloaded to an Rpi. You can find a video for V2 on the V2 sub-forum.
https://forum.universal-devices.com/topic/23859-polyglot-instruction-videos/
Edited by lilyoyo1
Thanks @lilyoyo1!  Because you make no mention of problems installing Polyglot-V2 on an existing RPi installation I'll go ahead with that.
There are no problems. Personally, I'd go ahead and get Polisy and install V3 on that. Developers are developing for that now so it's only a matter of time before V2 nodeservers become outdated.
No point in having to potentially do the same work twice
