Using ${sys.program.#.name} or ${sys.node.#.name} in Network Resources
With IoP we can now put ${sys.program.#.name} and ${sys.node.#.name} in the Path for Network Resource, but if the program or node name contains spaces it sends a bad post command.  Normally if the Path has spaces you can set "Encode URL" to fix them, but when using ${sys.program.#.name} you can't enable "Encode URL".  How do we get around that, besides naming the Programs with + signs instead of spaces?
This is an extremely using enhancement, but not being able to fix spaces makes it very limiting.   Or maybe I'm missing something?  I'm sure @MWareman or others must be using this?
