BUG - Node Server Info is Not Valid
BUG-  Tried to purchase ST-Inventory.   Says Node Server Info is Not Valid
If you fix I will buy right away!!
Looks like the trial period option of "week" is not valid on the backend.  Yet the option is presented in the web UI when adding the nodeserver.  I'll change the trial period and see what happens.
Also, when you click on the name of most nodeservers in the store it takes you to GitHub and you can read info on the nodeserver. This one takes you a private website with no info on the nodeserver.
Yes it takes you to the Simplex Technology website.  The nodeserver is not a public repo hosted on GitHub.  Documentation will be maintained on our website or other method.  Considering using Readthedocs for nodeservers for ease of maintenance.
I got it installed now but when I run it I get errors but I know the settings are correct.  I can put them into the pg2 version and they work
2022-02-16 15:17:34 info: NS: Starting Node Server 2022-02-16 15:17:34 info: POLY: Interface starting 2022-02-16 15:17:34 info: POLY: Getting config from environment 2022-02-16 15:17:34 debug: POLY: Log file set to: logs/debug-2022-02-16.log 2022-02-16 15:17:35 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:36 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:37 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:38 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:39 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:40 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:41 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:42 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:43 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:44 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:45 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:46 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:47 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:49 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:50 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:51 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:52 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:53 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:54 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:55 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:56 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:57 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:58 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:17:59 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:00 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:01 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:02 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:03 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:04 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:05 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:06 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:08 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:09 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:10 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:11 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:12 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:13 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:14 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:15 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:16 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:17 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:18 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:19 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:20 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:21 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:22 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:23 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:24 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:26 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:27 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:28 error: POLY: MQTT Error: Connection refused: Identifier rejected 2022-02-16 15:18:29 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:30 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:31 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:32 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:33 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:34 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:35 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:41 info: NS: Starting Node Server
2022-02-16 15:18:41 info: POLY: Interface starting
2022-02-16 15:18:41 info: POLY: Getting config from environment
2022-02-16 15:18:41 debug: POLY: Log file set to: logs/debug-2022-02-16.log
2022-02-16 15:18:41 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:42 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:43 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:44 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:45 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:46 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:47 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:48 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:49 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:50 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:52 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:53 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:54 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:55 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:56 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:57 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:58 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:18:59 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:19:00 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:19:01 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:19:02 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:19:03 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:19:04 error: POLY: MQTT Error: Connection refused: Identifier rejected
2022-02-16 15:19:05 error: POLY: MQTT Error: Connection refused: Identifier rejected
I've seen that error before when PG3 does not shutdown a nodeserver properly or the node process is not removed when the nodeserver crashes for some reason.  You can login to the Polisy and kill the node process and then start the NS or just reboot.
