PG3 CAO Wireless Tag Node server 3.1.7
The Polyglot Version 3 Node server for CAO Wireless Tags version 3.1.7 is released.  This just adds support for Quad Leak Sensor, hopefully someone running PG3 has one and can confirm it all works.
If you are going to buy a Tag Manager or any Tags, please use my affiliate link:  https://goo.gl/rXAGk9
See the README for more information, including information on moving from PG2.
The Release Notes are also available.
Please confirm you are on the latest version of PG3 which is 3.0.40 right now.
Edited by JimboAutomates
Change to 3.1.7
I already had the leak sensor installed but the NS doesn't seem to see it as a leak sensor after update. It acquires the tag type of the last tag viewed. I tried deleting the node in the NS reboot and discover but can't get the NS to recognize the leak sensor. Basically no data is loaded into the ISY. I think it is present in the NS. I attached a snippet.
Thanks Gary
Basically the AC is blank. It doesn't appear that any changes are loaded into the NS from the tag. I raised the temp on the tag but no changes were seen at the NS. Also GV12 doesn't change when wet.
Hi, Just tried V 3.1.3 and found one issue. When the leak sensor (Type 34) is queried the tag web site sends a notification that it could not call URL for "LeakSensor 5". I copied the info from that query. The other tag types work fine.
Thanks Gay
New Text Document.txt
Thanks, looks like Leak Sensors report lux and light state, I can add that.
2022-02-26 16:51:37,791 Command    udi_interface      ERROR    Tag:set_lux: 5:34:ca8f9c951a6968:Leak Sensor  5: does not have lux but was sent 3.388070821762085
2022-02-26 16:51:37,803 Command    udi_interface      ERROR    Tag:set_list: 5:34:ca8f9c951a6968:Leak Sensor  5: Is not configured for light state, let the author know it is needed value=0
Added issue: https://github.com/UniversalDevicesInc-PG3/udi-wirelesstag-poly/issues/51
  • 3 months later...
  • 3 months later...
      378.9k
