Authorizing V3 Access Shows as V2.
I purchased WirelessTag for PG3. After the install I selected the link to authorize the NS and the window that displayed is labeled for V2 Nodeserver access. See attached. I granted access and everything looked fine, but I ended up with only 2 nodes in IoP, no tag nodes.
I had V2 of this NS running on my ISY 994i and before installing V3 I deleted it from PG2. What I didn't do was Revoke Access to the V2 authorization in my WirelessTag Account. After Revoking access and then reinstalling V3 everything appears okay. It discovered all of my tags.
But, in my WirelessTag Account it is showing access to V2 not the V3 that I just set up. V3 NS appears to be telling WirelessTag Manager that it is still V2.
Image from WirelessTag Account:
1 minute ago, tmorse305 said:
The tags come up initially disabled, did you enable them in the AC?
All is fine, as I stated. It's just V3 is labeled as V2 in the Wireless Tag Manager.
Yes, I intended to create a new Oauth App for using PG3, but forgot to do that, so PG2 and PG3 are using the same one, which really doesn't matter.  Not sure why you had to revoke access, any should work.  I have multiple copies running with different auth keys.
I could still add a new OAuth App for PG3, but then everyone will have to re-auth.  Or I could just change the name of the App...
I actually installed V3 a couple times, and it would never discover my tags. I rebooted everything, clicked on Discover and set Montitor Tags True but they would never show up. It was then I discovered the Access settings in the Tag Manager and saw it was for version V2 back in 2021 when I first installed V2. So, I thought that was the problem and Revoked that access, reinstalled V3 and everything worked.
BTW... A WirelessTag has URL Calling parameters that get assigned, to what looks like, the Polyglot. If so, how can you have V2 and V3 both going at the same time?
Here's a URL Calling parameter example with V3.
http://192.168.1.158:23949/update?tmgr_mac=341A7A7179B1&name={0}&tagid={1}&temp={2}&hum={3}&lux={4}&ts={5}&batv={6}
You can not have multiple copies of the NS running, no matter if it's V2 or V3, you can only have one for that very reason.
