ronvond Posted March 12, 2022 Share Posted March 12, 2022 The Weatherflow subs appear in the left hand device tree, but the values do not update. Weatherflow True 1647110056 seconds Barometric Pressure o,o, Falling Humidity 0% Illumination 0,0,0 Lightning 0,0 Precipitation all zero Temperatures All zero f Wind 0, no wind, 0, no wind, 0 Link to comment Share on other sites More sharing options...
bpwwer Posted March 12, 2022 Share Posted March 12, 2022 It's likely either not configured correctly or something is blocking the node server from seeing the data. You need to provide more details and log output. Link to comment Share on other sites More sharing options...
ronvond Posted March 12, 2022 Author Share Posted March 12, 2022 Log output: 2022-03-12 11:28:13,006 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-03-12 11:28:14,269 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2022-03-12 11:28:14,271 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2022-03-12 11:28:14,696 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('10.0.0.1', 'igb0')}, 2: [('10.0.0.1', 'igb0', True)]} 2022-03-12 11:28:14,696 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('10.0.0.1', 'igb0') 2022-03-12 11:28:14,697 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'}] 2022-03-12 11:28:14,698 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'} 2022-03-12 11:28:14,700 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2022-03-12 11:28:14,752 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2022-03-12 11:28:14,753 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/3 - MID: 1 Result: 0 2022-03-12 11:28:14,754 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2022-03-12 11:28:14,755 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2022-03-12 11:28:14,759 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-03-12 11:28:14,761 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2022-03-12 11:28:14,808 Node server polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2022-03-12 11:28:14,809 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2022-03-12 11:28:14,810 Node server polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 0 2022-03-12 11:28:14,811 Node server polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2022-03-12 11:28:14,812 Node server polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2022-03-12 11:28:14,928 Node server polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 0 2022-03-12 11:28:15,223 Node server polyinterface ERROR weatherflow:query_wf: Bad: Expecting value: line 1 column 1 (char 0) 2022-03-12 11:28:15,224 Node server py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.0.38', 57303), raddr=('52.44.134.189', 80)> 2022-03-12 11:28:15,224 Node server py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.0.38', 57303), raddr=('52.44.134.189', 80)> 2022-03-12 11:28:18,248 Node server polyinterface ERROR hub:__init__: No sensor devices found (Sky, Air, Tempest) 2022-03-12 11:28:18,266 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py", line 770, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) TypeError: an integer is required (got type str) 2022-03-12 11:28:18,268 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-12 11:28:18,268 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-12 11:33:50,335 Controller polyinterface ERROR weatherflow:query_wf: Bad: Expecting value: line 1 column 1 (char 0) 2022-03-12 11:33:50,338 Controller py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.0.38', 45562), raddr=('52.44.134.189', 80)> 2022-03-12 11:33:50,338 Controller py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.0.38', 45562), raddr=('52.44.134.189', 80)> 2022-03-12 11:33:50,361 Controller polyinterface ERROR hub:__init__: No sensor devices found (Sky, Air, Tempest) Configuration: shortPoll 5 longPoll 60 AGL 0 Elevation 197 ListenPort 50222 Station https://tempestwx.com/station Units US Link to comment Share on other sites More sharing options...
bpwwer Posted March 12, 2022 Share Posted March 12, 2022 Station should be a station ID number not a URL. Link to comment Share on other sites More sharing options...
ronvond Posted March 12, 2022 Author Share Posted March 12, 2022 33 minutes ago, bpwwer said: Station should be a station ID number not a URL. Can you tell me where I find the station ID number. Looking in the settings tab on my iPad I see the station name is ST-00015014, which is the serial number of the unit. Under the station heading tab I see the name is "Our Home". I've also tried Lat/Lon. I restart the polisy after each change. ISY still shows the default readings. Link to comment Share on other sites More sharing options...
DennisC Posted March 12, 2022 Share Posted March 12, 2022 1 hour ago, ronvond said: Can you tell me where I find the station ID number. Looking in the settings tab on my iPad I see the station name is ST-00015014, which is the serial number of the unit. Under the station heading tab I see the name is "Our Home". I've also tried Lat/Lon. I restart the polisy after each change. ISY still shows the default readings. Use the Tempest app and go to: Settings - Stations - Select your station name - Status and read station ID. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 4 hours ago, DennisC said: Use the Tempest app and go to: Settings - Stations - Select your station name - Status and read station ID. I found the station ID. Thank you. Sadly I still have only the default data in ISY. The only change I noted was that the AGL value went from 0 to 6.096. 6 hours ago, bpwwer said: Station should be a station ID number not a URL. Can you tell me where I find the station ID number. Looking in the settings tab on my iPad I see the station name is ST-00015014, which is the serial number of the unit. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 I also rebooted both the Polisy and ISY. Link to comment Share on other sites More sharing options...
DennisC Posted March 13, 2022 Share Posted March 13, 2022 Is there a clue in the log? Have you completely and correctly completed the configuration, including a valid token? Token Your personal access to token. See https://tempestwx.com/settings/tokens ListenPort Port to listen on for WeatherFlow data. Default is port 50222 Rapid Wind Enable or disable the sending of rapid wind data to the ISY. Set to 'true' to enable. Rapid wind data is collected every 3 seconds Rapid wind data is only available for stations configured as 'local' Forecast Specifies the station id used for forecast data. If not set, no forecast data will be collected and not evaptrasnspiration calculations will done Stations A separate key/value for each station you want to collect data from The key is the station id number The value must be either 'local' or 'remote' 'local' - the data comes from the hub UDP feed on your local network 'remote' - the data comes from the WeatherFlow server at Short Poll intervals Link to comment Share on other sites More sharing options...
MBell Posted March 13, 2022 Share Posted March 13, 2022 9 hours ago, ronvond said: I found the station ID. Thank you. Sadly I still have only the default data in ISY. The only change I noted was that the AGL value went from 0 to 6.096. Can you tell me where I find the station ID number. Looking in the settings tab on my iPad I see the station name is ST-00015014, which is the serial number of the unit. The station ID is not the serial #. Go to settings, station name, status online and there you will find your station ID. It should be 5 numbers. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 15 hours ago, DennisC said: Is there a clue in the log? Have you completely and correctly completed the configuration, including a valid token? Token Your personal access to token. See https://tempestwx.com/settings/tokens ListenPort Port to listen on for WeatherFlow data. Default is port 50222 Rapid Wind Enable or disable the sending of rapid wind data to the ISY. Set to 'true' to enable. Rapid wind data is collected every 3 seconds Rapid wind data is only available for stations configured as 'local' Forecast Specifies the station id used for forecast data. If not set, no forecast data will be collected and not evaptrasnspiration calculations will done Stations A separate key/value for each station you want to collect data from The key is the station id number The value must be either 'local' or 'remote' 'local' - the data comes from the hub UDP feed on your local network 'remote' - the data comes from the WeatherFlow server at Short Poll intervals I did not have a "valid token" so created same. Now where should I enter that information? Link to comment Share on other sites More sharing options...
DennisC Posted March 13, 2022 Share Posted March 13, 2022 42 minutes ago, ronvond said: I did not have a "valid token" so created same. Now where should I enter that information? Go to the Node Server Configuration page and under Key type Token, under Value past your key. Save and restart the Node Server. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 I did that. Restarted the WeatherFlowPoly(3). Rebooted the Polisy. Rebooted the ISY. Still have nothing but default values in the ISY. Any more suggestions would be most welcome. Thanks for your help so far. Link to comment Share on other sites More sharing options...
DennisC Posted March 13, 2022 Share Posted March 13, 2022 14 minutes ago, ronvond said: I did that. Restarted the WeatherFlowPoly(3). Rebooted the Polisy. Rebooted the ISY. Still have nothing but default values in the ISY. Any more suggestions would be most welcome. Thanks for your help so far. Are you sure you correctly entered the Station ID? At this point, I suggest you send another log package to @bpwwer. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 2022-03-13 11:17:30,574 MQTT polyinterface ERROR weatherflow:query_wf: Bad: 'station_units' 2022-03-13 11:17:30,582 MQTT py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.0.38', 49144), raddr=('52.44.134.189', 80)> 2022-03-13 11:17:30,582 MQTT py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.0.38', 49144), raddr=('52.44.134.189', 80)> 2022-03-13 11:17:33,608 MQTT polyinterface ERROR hub:__init__: No sensor devices found (Sky, Air, Tempest) 2022-03-13 11:17:42,992 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-03-13 11:17:44,246 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2022-03-13 11:17:44,248 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2022-03-13 11:17:44,610 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('10.0.0.1', 'igb0')}, 2: [('10.0.0.1', 'igb0', True)]} 2022-03-13 11:17:44,611 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('10.0.0.1', 'igb0') 2022-03-13 11:17:44,612 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'}] 2022-03-13 11:17:44,613 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'} 2022-03-13 11:17:44,615 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2022-03-13 11:17:44,665 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2022-03-13 11:17:44,667 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/3 - MID: 1 Result: 0 2022-03-13 11:17:44,668 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2022-03-13 11:17:44,668 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2022-03-13 11:17:44,672 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-03-13 11:17:44,674 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2022-03-13 11:17:44,719 Node server polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2022-03-13 11:17:44,720 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2022-03-13 11:17:44,721 Node server polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 0 2022-03-13 11:17:44,722 Node server polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2022-03-13 11:17:44,722 Node server polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2022-03-13 11:17:44,838 Node server polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 0 2022-03-13 11:17:45,017 Node server polyinterface ERROR weatherflow:query_wf: Bad: 'station_units' 2022-03-13 11:17:45,018 Node server py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.0.38', 30203), raddr=('54.209.237.67', 80)> 2022-03-13 11:17:45,018 Node server py.warnings WARNING warnings:_showwarnmsg: /var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('10.0.0.38', 30203), raddr=('54.209.237.67', 80)> 2022-03-13 11:17:45,037 Node server polyinterface ERROR hub:__init__: No sensor devices found (Sky, Air, Tempest) 2022-03-13 11:17:45,052 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py", line 770, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) TypeError: an integer is required (got type str) 2022-03-13 11:17:45,054 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 11:17:45,054 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 13:53:54,825 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-03-13 13:53:55,896 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2022-03-13 13:53:55,898 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2022-03-13 13:53:56,222 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('10.0.0.1', 'igb0')}, 2: [('10.0.0.1', 'igb0', True)]} 2022-03-13 13:53:56,222 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('10.0.0.1', 'igb0') 2022-03-13 13:53:56,223 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'}] 2022-03-13 13:53:56,224 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'} 2022-03-13 13:53:56,225 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2022-03-13 13:53:56,269 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2022-03-13 13:53:56,270 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/3 - MID: 1 Result: 0 2022-03-13 13:53:56,270 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2022-03-13 13:53:56,271 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2022-03-13 13:53:56,275 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-03-13 13:53:56,277 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2022-03-13 13:53:56,323 Node server polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2022-03-13 13:53:56,323 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2022-03-13 13:53:56,324 Node server polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 0 2022-03-13 13:53:56,325 Node server polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2022-03-13 13:53:56,326 Node server polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2022-03-13 13:53:56,427 Node server polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 0 2022-03-13 13:53:57,266 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py", line 770, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) TypeError: an integer is required (got type str) 2022-03-13 13:53:57,268 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 13:53:57,268 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 13:56:29,500 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-03-13 13:56:30,725 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2022-03-13 13:56:30,727 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2022-03-13 13:56:31,149 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('10.0.0.1', 'igb0')}, 2: [('10.0.0.1', 'igb0', True)]} 2022-03-13 13:56:31,150 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('10.0.0.1', 'igb0') 2022-03-13 13:56:31,151 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'}] 2022-03-13 13:56:31,152 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'} 2022-03-13 13:56:31,155 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2022-03-13 13:56:31,218 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2022-03-13 13:56:31,220 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/3 - MID: 1 Result: 0 2022-03-13 13:56:31,221 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2022-03-13 13:56:31,222 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2022-03-13 13:56:31,229 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-03-13 13:56:31,236 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2022-03-13 13:56:31,363 Node server polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2022-03-13 13:56:31,365 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2022-03-13 13:56:31,365 Node server polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 0 2022-03-13 13:56:31,368 Node server polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2022-03-13 13:56:31,369 Node server polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2022-03-13 13:56:31,523 Node server polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 0 2022-03-13 13:56:35,445 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py", line 770, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) TypeError: an integer is required (got type str) 2022-03-13 13:56:35,446 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 13:56:35,446 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 14:04:36,607 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-03-13 14:04:37,644 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2022-03-13 14:04:37,646 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2022-03-13 14:04:37,927 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('10.0.0.1', 'igb0')}, 2: [('10.0.0.1', 'igb0', True)]} 2022-03-13 14:04:37,927 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('10.0.0.1', 'igb0') 2022-03-13 14:04:37,928 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'}] 2022-03-13 14:04:37,929 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'} 2022-03-13 14:04:37,930 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2022-03-13 14:04:37,974 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2022-03-13 14:04:37,976 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/3 - MID: 1 Result: 0 2022-03-13 14:04:37,976 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2022-03-13 14:04:37,977 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2022-03-13 14:04:37,981 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-03-13 14:04:37,984 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2022-03-13 14:04:38,069 Node server polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2022-03-13 14:04:38,070 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2022-03-13 14:04:38,070 Node server polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 0 2022-03-13 14:04:38,071 Node server polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2022-03-13 14:04:38,072 Node server polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2022-03-13 14:04:38,176 Node server polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 0 2022-03-13 14:04:39,070 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py", line 770, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) TypeError: an integer is required (got type str) 2022-03-13 14:04:39,072 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 14:04:39,072 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 14:40:37,860 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-03-13 14:40:39,016 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2022-03-13 14:40:39,017 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2022-03-13 14:40:39,295 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('10.0.0.1', 'igb0')}, 2: [('10.0.0.1', 'igb0', True)]} 2022-03-13 14:40:39,296 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('10.0.0.1', 'igb0') 2022-03-13 14:40:39,297 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'}] 2022-03-13 14:40:39,297 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'} 2022-03-13 14:40:39,299 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2022-03-13 14:40:39,342 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2022-03-13 14:40:39,343 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/3 - MID: 1 Result: 0 2022-03-13 14:40:39,344 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2022-03-13 14:40:39,344 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2022-03-13 14:40:39,348 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-03-13 14:40:39,350 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2022-03-13 14:40:39,438 Node server polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2022-03-13 14:40:39,439 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2022-03-13 14:40:39,439 Node server polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 0 2022-03-13 14:40:39,441 Node server polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2022-03-13 14:40:39,441 Node server polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2022-03-13 14:40:39,559 Node server polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 0 2022-03-13 14:40:43,393 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py", line 770, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) TypeError: an integer is required (got type str) 2022-03-13 14:40:43,396 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 14:40:43,396 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 14:42:25,392 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-03-13 14:42:26,365 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2022-03-13 14:42:26,366 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2022-03-13 14:42:26,675 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('10.0.0.1', 'igb0')}, 2: [('10.0.0.1', 'igb0', True)]} 2022-03-13 14:42:26,675 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('10.0.0.1', 'igb0') 2022-03-13 14:42:26,676 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'}] 2022-03-13 14:42:26,677 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '10.0.0.38', 'netmask': '255.255.255.0', 'broadcast': '10.0.0.255'} 2022-03-13 14:42:26,678 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2022-03-13 14:42:26,720 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2022-03-13 14:42:26,722 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/3 - MID: 1 Result: 0 2022-03-13 14:42:26,722 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2022-03-13 14:42:26,723 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2022-03-13 14:42:26,726 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-03-13 14:42:26,729 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2022-03-13 14:42:26,814 Node server polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2022-03-13 14:42:26,816 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2022-03-13 14:42:26,816 Node server polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 0 2022-03-13 14:42:26,818 Node server polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2022-03-13 14:42:26,818 Node server polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2022-03-13 14:42:26,913 Node server polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 0 2022-03-13 14:42:27,655 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/node servers/WeatherFlowPoly/nodes/weatherflow.py", line 770, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) TypeError: an integer is required (got type str) 2022-03-13 14:42:27,659 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2022-03-13 14:42:27,659 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> Link to comment Share on other sites More sharing options...
DennisC Posted March 13, 2022 Share Posted March 13, 2022 Are you on PG2? If so, I think I previously posted instructions for PG3. It's been awhile since I set up Weatherflow on PG2, so I am not sure if setup is the same, however, I don't think key "Our Home" is a correct key. I don't think you are configuring the setup correctly. I would suggest deleting your current keys, restarting the Node Server, and configuring per the directions. I "think" the correct keys for PG2 are: AGL, Elevation, Listen Port, Station, Tempest, Units. You could also post the instructions from configuration page here and some one can help using what you posted above. One last thought, if Our Home is your Token for PG3, you might want to delete it from your Weatherflow account. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 I'm using Polisy Version 2.2.13, Frontend 2.2.9-5, ISY 5.3.3. I did delete all the keys and restart WeatherFlowPoly. The keys were repopulated with the proper information. I'm wondering if there's something I need to change to allow ListenPort 50222 access to my system. WeatherFlowPoly_3-13-2022_33355_PM.txt Link to comment Share on other sites More sharing options...
DennisC Posted March 13, 2022 Share Posted March 13, 2022 17 minutes ago, ronvond said: I'm using Polisy Version 2.2.13, Frontend 2.2.9-5, ISY 5.3.3. I did delete all the keys and restart WeatherFlowPoly. The keys were repopulated with the proper information. I'm wondering if there's something I need to change to allow ListenPort 50222 access to my system. WeatherFlowPoly_3-13-2022_33355_PM.txt 40.97 kB · 0 downloads I don't have any further suggestions for you. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 I appreciate all the effort you put into helping. Perhaps someone else will pick this up. Link to comment Share on other sites More sharing options...
bpwwer Posted March 13, 2022 Share Posted March 13, 2022 there are a couple of errors in the log. First, it seems to be having problems getting your station's information from the WeatherFlow servers. Whatever it is getting back from the query is not what is expected. It is also complaining about the port number. I've never seen it do that before so I have no idea what's happening there. I don't really have time to support the PG2 version as that's basically end of lifed at this point in favor of the PG3 version. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 Can I update to the PG3 version? How? Link to comment Share on other sites More sharing options...
DennisC Posted March 13, 2022 Share Posted March 13, 2022 15 minutes ago, ronvond said: Can I update to the PG3 version? How? PG3 only runs on a Polisy. If you have one follow the directions in the Polisy thread. Iy you don't have one, I believe UD is currently offering a discount. Send them an email and ask. Link to comment Share on other sites More sharing options...
ronvond Posted March 13, 2022 Author Share Posted March 13, 2022 I have Polisy Version 2.2.13, Frontend Version 2.2.9-5, ISY version 5.3.3 Link to comment Share on other sites More sharing options...
DennisC Posted March 13, 2022 Share Posted March 13, 2022 8 minutes ago, ronvond said: I have Polisy Version 2.2.13, Frontend Version 2.2.9-5, ISY version 5.3.3 Go to help about and post a screenshot. You have this? Link to comment Share on other sites More sharing options...
ronvond Posted March 14, 2022 Author Share Posted March 14, 2022 Yes I do. Link to comment Share on other sites More sharing options...
