Email / System Configuration
I apologize in advance if I missed the thread, but I seem to no longer be able to save email / cell addresses. I had this working in 2.4.12 but now when I add them, they show up on the right pane, and I can appear to save them...but if I exit ISY and come back to the Configuration tab the next time they are gone.
I saw the post re: 2.4.13 fixes referencing the removal of notification settings from Configuration tab. Am I missing something or just in my usual late-night instefog?
Trying to set up a Home Alone button that notifies me when my son gets home from school.
TIA,
marko
For Next Drop -
For 2.4.13 -
Fixes
- Removed notification settings from Configuration tab
Marko,
You're 100% correct. This is a regression and has already been fixed. Unfortuantely, you cannot save your notifications setting on this release unless you already had one stored. Or, if you wish, you can use http://www.universal-devices.com/beta just to save your configuration settings and then revert back to your default URL for ISY.
TIA,
marko
For Next Drop -
For 2.4.13 -
Fixes
When are the notification settings going to make it back in? Just installed 2.4.15 and still cannot save email/mobile settings.
Hello Michel,
Oops, sorry forgot to clear the cache... it works now, but here are some comments:
- Time is incorrect (off by several minutes) ... I assume this is due to your mail server clock difference
- Text is incorrect: it states the On has turned to Off when in reality it was the other way around
- Minor item but can the "In the" on line 3 be removed? Personally, I would prefer just listing the device name and the change in status. Or even better: give me a choice of my own text.
This is from KPL button G/7 going from off to on:
         Control '*Home Alone' is switched On
         Send Notification to All
Thanks ... every thing else is checking out OK. Great job!
1) You are correct about the reasons for the time difference.
2) I'll take a look at why it is sending 'Off' instead of 'On'.
3) I agree, the mail templates for these messages need to be cleaned up, and made customizable, although I'm not sure if it will make it in the 2.5 release.
Thanks for the feedback!
Just want to let you know I'm still receiving incorrect text in the notification (v2.6). The device transitioned from off to on, but the message is stating the opposite:
On Alert!
To: xxx@nnn.net
Subject: On Alert!
Date: Dec 22, 2007 4:59 PM
12/22/2007 16:56:37:
In Insteon Network At 7078 Russell Court:
In the *Home Alone,On has changed to Off.
*** Service Machine. DO NOT REPLY ***
maui4marko,
Thanks so very much for the update and so very sorry for the inconvenience. I have captured it as a bug and we shall take care of it as soon as possible.
On Alert!
To: xxx@nnn.net
Subject: On Alert!
  • 10 months later...
