ecobee NS not communicating with thermostats
Hi @JimboAutomates,  I'm running version 3.0.2 on Polisy 3.0.55 with ISY at 5.4.2.  From the AC perspective everything seems ok, the NS is up there are values populated for the thermostats that seem correct.  I cannot control the thermostats from the AC however.  If I try to change the fan mode for example nothing happens.  Looking at the NS, the log will not display there is only one long entry:
2022-04-04 13:21:08,111 Thread-5974 urllib3.connectionpool WARNING connectionpool:urlopen: Retrying (Retry(total=29, connect=30, read=29, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='api.ecobee.com', port=443): Read timed out. (read timeout=10)")': /1/thermostat?json=%7B%22selection%22%3A+%7B%22selectionType%22%3A+%22thermostats%22%2C+%22selectionMatch%22%3A+%22521789884617%22%2C+%22includeEvents%22%3A+true%2C+%22includeProgram%22%3A+true%2C+%22includeSettings%22%3A+true%2C+%22includeRuntime%22%3A+true%2C+%22includeExtendedRuntime%22%3A+true%2C+%22includeLocation%22%3A+true%2C+%22includeEquipmentStatus%22%3A+true%2C+%22includeVersion%22%3A+true%2C+%22includeUtility%22%3A+true%2C+%22includeAlerts%22%3A+true%2C+%22includeWeather%22%3A+true%2C+%22includeSensors%22%3A+true%7D%7D, that's it.
Under the node tab there are no nodes.  I've have tried a couple of restarts but no luck.  Suggestions?
Thank you.
