FortrezZ MIMO2+
I keep getting an unable to securely add device which limits me to one relay.  This worked in 994i as im just trying to migrate to polisy. Any thoughts?
Solved the secure add issue my moving closer to zooz.  Still having issue where the second relay and sensor are not showing in Polisy.  Have updated Zooz to 7.17 removed and added ForentzZ several times with the same result (yes i realize thats the definition of insanity... expecting a different result).  Attached is the log of the last attempt and the documentation for the FortenzZ which again was working perfectly on the 994i.
The fail message in the log is Thu 04/14/2022 05:07:54 PM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x8E.02 MULTI_CHANNEL_ASSOCIATION.  Probably just my vision but appears while installing second relay and sensor its using the same name? Cursor highlight appears to be flipping back and forth in the node tree.
Thanks for the assistance in advance..
ISY-Events-Log.v5.4.3__Thu 2022.04.14 05.09.15 PM.txt User+Manual+MIMO2++8May2017+removed+MI+address.pdf
Edited by pjjameso
So I thought i would try the zooz zen17 universal relay, good choice as everything is working as expected.
Edited by pjjameso
