January 11, 201016 yr Is there a listing of EZ I/O module compatability? otherwise can you advise which I/O modules a known to be 100% compatable - thanks
January 11, 201016 yr Hi helipal, Currently IOLinc is 100% compatible. All EZxxx modules are hit or miss depending on their firmware version. With kind regards, Michel
January 11, 201016 yr Author Thanks for the reply - to confirm, the I/O linc is the single input / single output unit that SM also sells as a 4 pack? Since SM is out of these, anyone else that also carries them (or is SM prime source) Thanks for you help Michel - This is my 3rd home atomation controller, and definetly the best! Your team makes a great product, with great support, and I love the contiuos improvment to make it better! On a differant note - I'm thinking of purchasing the venstar T1800 thermostats - is it possible to use their local measured tempature and humidity (with the add on) as conditions in programs?
January 11, 201016 yr Hi helipal, Thanks so very much for your words of encouragement! They mean a lot. 1. Unfortunately SH is the only place where you can buy the IOLincs 2. Yes, you can use T1800 in combination with ISY v.27.9 and above to receive humidity and local temperature with ISY With kind regards, Michel
