UD Mobile - iOS
Beta Version 1.1.0
Added PG3 UI for Local Connections.  Added PG3x Remote UI for PG3x (Portal account required).  Please report any issues on the Universal Devices Forum. Note that Local Connections require that Local Connection Settings are enabled and valid for your System (Settings-Tab > Systems > Your System > Local Connection Settings). Local Connection Settings requires location permission and your WiFi SSID. Polisy requires manual upgrade to PG3x for remote connections, eisy shipped with PG3x.
  • 1 month later...
Production 1.1.7
Added basic Notification Node Server setup and configuration. See the following video for instructions or our WiKi for some common issues when upgrades are required.
Allow Widgets (slider/switch/etc.) for commands with multiple parameters. This should allow widgets for most Z-Wave devices.  https://wiki.universal-devices.com/index.php?title=UD_Mobile#Missing_Widget
Automatically open System Folder if there is a single system on Home Tab.
Beta 1.1.9
Added streaming video/camera support. To access cameras outside of your home network they must be accessible outside of your home network.  PG3 Plugin support, coming soon, will allow developers to add streaming video support to their Node Server Plugins.
Basic setup example.
  • 3 months later...
Beta 1.1.30
Added custom thermostat view. During testing the view must be set manually, in the future this may be done automatically assuming the node server conforms to Thermostat.  Enable the custom thermostat view from the Node's Dashboard (the view with all node's status and command), select setting (gear icon at top, same location as image below), select Dashboard View, select thermostat.  This should work with most thermostats, Ecobee and Honeywell Node Servers appear to work, although the current status (heating/cooling/idle) on the ecobee does not appear to conform to thermostat status so icon for status may be static (non-changing).
  • 4 months later...
Beta 1.1.52
Updated Device Dashboard (aka Node Dashboard) cells and added new menu to select cell type.
Added alpha Device Property History (aka Status History).  During initial testing you must enable capture of status history, this will likely be enabled by default in a future firmware version.  During alpha testing we are only trying to verify this does not overwhelm eisy, especially users with large systems. Chart options, improvements, and favorites tiles coming soon.
See: https://wiki.universal-devices.com/UD_Mobile#Status_History
