Want to add my ISY994i to the portal
Solved by kzboray
@DClausen When you start ISY Launcher the UUID will be listed for all located ISY's including IoP's.
@DClausen Also, there are directions on the Wiki - https://wiki.universal-devices.com/index.php?title=ISY_Portal_Installation_Instructions
Quote
ISY Portal Account Setup
There are three steps for having ISY communicate through ISY Portal:
1. Creating an account on " ISY Portal if one does not exist (click on the Create new account link). If one already exists, simply login
2. Registering ISY with your account in ISY Portal using ISY's UUID (Help | About - also included in your invoice). To do this click on the Add ISY button and copy/paste the UUID from your invoice or order notification
3. Giving permission to ISY to communicate with ISY Portal
  • Login to the Admin Console
  • Click Configuration | Portals tab
  • You will see a request for access from your account in ISY Portal
  • Approve it
  • You are done!
