jlamb Posted April 30, 2022 Posted April 30, 2022 (edited) Can anyone tell me how to completely delete polisy and start from scratch? I’ve got a few strange things going on that I have been unable to resolve. Seems I’m somehow getting old config files to keep loading into PG2 and pg3 even when I delete them. It’s causing problems when I’m trying to configure PG2/pg3 and node servers. Wanting to just delete everything and do a clean install. I would then restore isy from a backup and start PG2 and PG3 from fresh install. I did a factory reset and it seems it still had some items saved from some kind of config file. Thank you, Jasson Edited April 30, 2022 by jlamb
G W Posted April 30, 2022 Posted April 30, 2022 I'd like to know this top. I tried holding the reset button but after 60 seconds, I gave up.
larryllix Posted April 30, 2022 Posted April 30, 2022 I don't believe a total wipe has been programmed into IoP yet. Good idea! Before anybody starts populating their IoP with programs, save an empty backup!
lilyoyo1 Posted April 30, 2022 Posted April 30, 2022 On 4/30/2022 at 6:30 AM, jlamb said: Can anyone tell me how to completely delete polisy and start from scratch? I’ve got a few strange things going on that I have been unable to resolve. Seems I’m somehow getting old config files to keep loading into PG2 and pg3 even when I delete them. It’s causing problems when I’m trying to configure PG2/pg3 and node servers. Wanting to just delete everything and do a clean install. I would then restore isy from a backup and start PG2 and PG3 from fresh install. I did a factory reset and it seems it still had some items saved from some kind of config file. Thank you, Jasson Expand This is what Michel said once. Sudo pkg delete isy Sudo pkg install isy 1
jlamb Posted April 30, 2022 Author Posted April 30, 2022 On 4/30/2022 at 1:04 PM, lilyoyo1 said: This is what Michel said once. Sudo pkg delete isy Sudo pkg install isy Expand Does that delete just the isy package or does that delete everything?
lilyoyo1 Posted April 30, 2022 Posted April 30, 2022 On 4/30/2022 at 2:07 PM, jlamb said: Does that delete just the isy package or does that delete everything? Expand Just the Isy as far as I know.
bpwwer Posted April 30, 2022 Posted April 30, 2022 Neither PG3 nor PG2 are designed to be fully deleted from the system. However, If you want to clear PG3 of all settings and return to all defaults you can do the following from the ssh command line: sudo service pg3 stop sudo rm /var/polyglot/pg3/pg3.db sudo service pg3 start this will remove the PG3 database (which is the only configuration file it has) and PG3 will re-created it with default when it starts. I don't know how to do that same thing with PG2 as it uses a different database to hold it's configuration.
jlamb Posted April 30, 2022 Author Posted April 30, 2022 On 4/30/2022 at 2:49 PM, bpwwer said: Neither PG3 nor PG2 are designed to be fully deleted from the system. However, If you want to clear PG3 of all settings and return to all defaults you can do the following from the ssh command line: sudo service pg3 stop sudo rm /var/polyglot/pg3/pg3.db sudo service pg3 start this will remove the PG3 database (which is the only configuration file it has) and PG3 will re-created it with default when it starts. I don't know how to do that same thing with PG2 as it uses a different database to hold it's configuration. Expand Thank you for the information. If anyone knows how to do that with PG2, it would be much appreciated! Jasson
larryllix Posted April 30, 2022 Posted April 30, 2022 On 4/30/2022 at 2:55 PM, jlamb said: Thank you for the information. If anyone knows how to do that with PG2, it would be much appreciated! Jassonif you are running on an RPi you would reimage the SD card. PG2 has so many parameter files it will likely never be revealed. Me thinks PG3 does also.Sent from my SM-G781W using Tapatalk
jlamb Posted April 30, 2022 Author Posted April 30, 2022 On 4/30/2022 at 5:10 PM, larryllix said: if you are running on an RPi you would reimage the SD card. PG2 has so many parameter files it will likely never be revealed. Me thinks PG3 does also. Sent from my SM-G781W using Tapatalk Expand I am running on a Polisy.
