January 17, 201016 yr I have an 8-button KPL relay which controls my landscape lights (button A). Button B has, for at least two years, been a controller of the "Family Room Lights-Full" scene in my family room. That scene includes three LampLincs as responders, and a secondary button on a KPL dimmer in another location as a controller. I have been applying the ISY alpha builds, and and have been on 2.7.8. After replacing one of the older LampLincs in my family room with a new Dual-Band LampLinc Dimmer, I checked the on levels/ramp rates in the scene and discovered that the ramp rate on the KPL dimmer is greyed out (remember, this is button B, not the load). I'm 99.9% sure that the ramp rate on the secondary buttons on the KPL Relay used to be adjustable. I tried the following fixes, all of which were unsuccessful: Query the KPL RelayRestore the KPL RelayRemove the KPL Relay from the scene and add it backUpgrade to 2.7.9 Alpha. Any suggestions?
January 18, 201016 yr Hi Tim, Even if ramp rates on the secondary buttons were adjustable it must have been a bug since secondary buttons do not have any on level/ramp rate associated with them. If you are talking about ramp rates/on level for devices responding to a secondary button, then that must be a bug. Is this the case only for your LL? With kind regards, Michel
