node servers show Unmanaged
I had this posted before, but I see its closed. I was unable to work on this project recently.
I followed the instruction from Mr. Bill. I'm now able to find my Polisy using ISY launcher and launch Polyglot V3 (PG3). My previously installed node servers show "Unmanaged". When I install a new Node server it show "Connected". I'd like to delete all my installed node servers and start over, but I can't uninstall the ones that are "Unmanaged" I've done a factory reset using the reset button, but they still show up when I reconnect. Any ideas?
Since you're using polisy and PG3, your old node servers from pg2 would show unmanaged since that's a different setup. You would log into PG2 and delete those node servers from there
Edited by lilyoyo1
It doesn't let me launch Polyglot V2. It says "site can't be reached". To be fully transparent, I am trying to connect through a VPN, but I don't know why that would be a problem when I can launch V3 the same way.
Can't help you through vpn since i don't use mine through one. You could make sure you have the correct port attached for V2
If you're not planning to use PG2 or need to see the configurations for the node servers there, you can simply delete the node servers from the ISY.  From the admin console go to Node Servers -> Configure -> <slot> -> click the Delete button.
PG3 may take a few minutes to recognize that it's gone from the ISY but after 5 minutes or so, the unmanaged entry should go away and the slot is now free to install a node server.
