Debugging Programs not running
Hi, new to the ISY/Polisy. I am one of the Insteon refugees switching everything over to Z-Wave.
So far, I have about half my devices moved over, with about 10 of them configured on the ISY? part of the Polisy.
I've been trying to setup some programs but with no luck. We're looking to get notifications when a door sensor is opened and I've setup + tested Pushover. However, it seems like none of my programs 'run" despite being enabled.
How can I debug this? I've checked the logs and don't see anything. Screens posted:
https://i.imgur.com/K0dj8Tv.png
What is Catlight-Off Power Switch?  Do you see it changing on the "Main" device tree as the state changes?   You likely want "control" instead of "status", but status should work if the status is actually changing.
@ARyder01 the reply by @DennisC just made me realize the problem here.
Your My programs folder has a RED stripe.  That tells me you have a FOLDER condition enabled on that folder.  If a folder condition is False (yours is because it's RED, not GREEN) nothing below that in the tree will work.  Even when run manually like @DennisC suggests.
Folder conditions are unlike Program conditions in that anything below a false folder condition will never be seen, even if run manually or run by another program.
I'd recommend staying away from folder conditions at the beginner and intermediate level, wait until you're really good at programming to use.  They trip a lot of people up.
