Programming window resize?
Is there a way to resize the program content window?  It was always more or less maximized  with the "Add to program" being just large enough to see everything and the "Program Content" occupying the rest of the screen.  Somewhere along the way, don't recall if it was the move to a new laptop along with win 10 to 11 or the jump from ISY to IoP but every time when I initially log into ISY and load the programming windows the Content window is just a couple of lines at the top of the screen and Add to occupies the rest.  I can grab the bar in the middle and drag it down, but is there some way to make it stick?
Solved by MrBill
Try deleting these temp files and see if that resolves your issue, probably just the 2nd and/or 3rd would do it, I usually just search udi_* in that Temp directory and nuke em all.
find the following files in Java temp directory (on Windows: c:\Users\[Username]\AppData\Local\Temp) and delete them. Or, you can simply search the computer for udi_*.* file patterns:
  • udi_tree.state
  • udi_frame.state
  • udi_pgm.state
  • udi_finder.state
  • udi_launcher.state
