cannot access polisy dashboard
new to polisy:
after following initial start process, I was able to log into polisy PG3 but I get no dashboard. it states i have logged in but remains on the login screen. i also noticed that the date is way off (2017) via ssh "date" cmd. I made sure timezone is correct & tried "sudo date 220516" but it doesnt work. I tried factory resetting polisy but still nogo.
sudo uname -r <13.0-RELEASE-p11>
I'm not an expert but after I login it displays the dashboard at this url. You might try logging in and then browse to that url. Just a thought.
<ip address>:3000/dashboard
https://192.168.1.158:3000/dashboard
Edited by vbphil
Are you able to access the Polisy from the admin console?
What browser are you using?
Also try pushing the reset / update button once on the right front of the Polisy using
when I try that, It immediately redirects me back to the login scn.
I'm using chrome with latest updates. I tried both hard reset (3x flashing lights) & single button press which didn't seem to do anything. I also tried manual upgrade <sudo pkg update, sudo pkge upgrade & sudo service pg3 restart> but it throws allot of errors & doesn't update.
excerpt for sudo pkg update:
[admin@polisy ~]$ sudo pkg update
Password:
Updating FreeBSD-base repository catalogue...
Certificate verification failed for /C=US/O=Let's Encrypt/CN=R3
34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915:
Fixed, it was all due to the wrong date. I finally got the date cmd to run & now it all works :-)
