Posted January 23, 201015 yr the web server stops working every day. reboot it and it works fine. Everything else still works but i can't log into it through a web browser.
January 24, 201015 yr Hi richardl007, Apologies for the inconvenience. Would you be kind enough to let me know: 1. Which firmware version does your ISY have? 2. Do you access your ISY remotely using HTTPS? 3. When the web server stops, can you access ISY locally at home? With kind regards, Michel the web server stops working every day. reboot it and it works fine. Everything else still works but i can't log into it through a web browser.
